Question about Cell Phones
Can't get on line. Phone freeze on connection
  • 73 Answers
Try installing another mobile phone internet browser.
or may be you storage is too little.
Posted on May 25, 2011
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
I can't get my lexmark x2600 all in one to fax
You maybe having problems with your fax phone line.
To check this phone line, connect a phone handset to this phone line and see if you get a dial tone and you can dial out.
If not then you need to get the phone line repaired.
Oct 26, 2012 | Lexmark X2600 All-In-One InkJet Printer
Now it is saying check tel line
There's some problem with the phone's ability to detect a dial tone. Check that the phone's base is connected to your home's AC power and the telephone cord is securely connected at the phone base and wall jack. If still not working, continue checking by disconnecting the cord from the base and connecting a different working phone. If the phone does not work while connected to this cord - there's a problem with the cord. Try replacing the cord between the jack and phone. If it still won't work - you may need to contact your telephone company's repair service to get it fixed. Good luck!
May 27, 2012 | Panasonic KXTG4011 Cordless Phone
Cell phone freeze
If the Phone says Phone Freeze it's because of wrong code entered.It's Samsung Phone ?Because samsung Phone will say Phone Freezed..You need to Unfreeze it using the Unfreeze Code.You can get the Unfreeze code for Samsung Phone European Phones at Unlocking4u.com/samsung-europe-unlocking-service/rs6wp10/ and Unfreeze it
May 25, 2012 | Cell Phones
WILL NOT CALL OUT SAYS TO CHECK ISDN LINE WE ARE NOT USING ISDN LINES WE USE THE INTERNETWhat's your problem?
When you use the internet you are using a connection to your ISP (Internet Service Provider) over some kind of line whether it is a phone line using a modem or a cable for a cable modem. ISDN is just another way that you connect to the internet. ISDN stands for Integrated Services Digital Network. ISDN is a digital phone connection system and is often used to give you higher and more reliable service. So, what they mean is to call your phone company and ask them to check your line, that is all they mean. Remember, the Internet itself is just a huge set of connections using an unbelievable number of types of connectivity from phone lines to space based relays and how you get there is through whatever line you have set up between you and your ISP. Does that help?
May 23, 2012 | Polycom Viewstation Pvs-14xx & More...
How do i connect phone to laptop connection
So do you have internet service at the house? If so you can plug the ethernet cable from the modem directly into the computer's ethernet port.
If you're talking about directly connecting to your cell phone, then the phone has to have the built in router in it. If it does, you can connect your computer to it wirelessly.
If you're talking about a regular old house phone (land line) then you would be very slow if you could get it connected. I don't think the newer models of computers even have a modem port to connect a telephone line into it. But basically you would still need a internet service provider to connect it.
Bear in mind that there is a difference between the phone cord and the ethernet cord. The phone cord is smaller in size and the end that plugs in is smaller.
Apr 03, 2012 | Computers & Internet
Panasonic KX-T7030 won't answer. When you lift up the receiver and pick a line the speakerphone button lights up and the phone is inoperable. It's not the phone it's the phone line. Any phone...
Try unplugging the phoen and plug a single line telephone into the port. If it doesn't work, you have your answer. The voice pair, which will use the inner pair of a 4 conductor cable needs to be working before the multi-line set will work. I'm guessing you have the data path but not the voice. The phone looks like it works, but there is no sound.
Carl
Oct 05, 2011 | Panasonic KX-T7030 Corded Phone
I have an AT&T 958 speakerphone. I need to transfer a call to another number so I press flash then dial the number. But, when i press flash again to connect the 2 calls, I too am connected and its a...
This is a standard phone so I'm assuming you're using this in a home or small office, connected direct to a regular phone line, and that you're using calling services from your phone service provider. 3-way calling works as you describe: you press flash to get dialtone again, call the other party, then press flash again to connect the two so all three of you can talk. The point is that this is 3-way calling, not a forwarding or transfer function. You can't transfer a call to another number this way. Since you initiated the 3-way call, the connection requires you to be there; when you hang up the connection between the other two parties is broken.
Your line may also have call-forwarding, which lets you program a number that calls to your line will reach if you're away (an alternative to using voicemail or an answering machine and needing to check messages). But this doesn't allow you to transfer a current call to another number, only incoming calls.
The only way you can transfer a call is when you have the switching equipment (an office phone system, for example) at your location, and have at least two outside phone lines available. Then the system would allow your phone to disconnect, and still maintain the connection between the other parties. But both of the phone lines would remain tied up until the other parties hung up, and if you only had two lines you'd be unable to receive or make any other calls.
Residential customers with a single phone line don't have any option to transfer calls.
Jun 07, 2011 | AT&T 958 Speakerphone (att26835)
Freezes and rebooted. Mostly freezes
Hello and welcome to FixYa;
You didn't specify what type of LG phone you have;
You can try rebooting it as an option; or (cycle it once a day).
Turn phone off. Take off cover; take out battery, sim card (if your model has one);
keep them out for a couple of minutes;
replace sim card (if your model has one), replace battery; and turn phone back on.
You could try 'resetting' your phone; but all models are different and you didn't give me the model number.
Try this and see if it works for you; also, when you take battery off, you can try to gently clean the battery terminals for debris. A phone will reboot if the battery is gunked up or not making a good connection.
Sorry i couldn't give you more to go on with the information you provided. Hope that helps.
kittytech
May 31, 2011 | LG Cell Phones
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
