Question about Toshiba TEC B SX4T Printer
Hi, i have a tec sx4t which has suddenly started to jam it will drive about two labels and stop i have cleaned the sensors and roller from dust etc. Regards Roy C
    Champion:
  • 254 Answers
DO a sensor callibration in the sensor adj menu
Posted on Aug 16, 2011
Mx2600n is having paper jam BTW the black and white roller before the Fuser unit
There are a number of reasons why the paper would jam at registration. First off, if the paper is completely flat & straight it is probably a feed issue or paper detect issue. There are 2 little black photo reflectors before the rollers in the centre of the feed path. These sensors can get covered with paper dust & may need cleaning. Also try feeding paper from the manual feed tray & see if it jams. If you have jams from both cassette's & manual feed then its most likely a sensor of feed issue. If its from one tray only then the sensors in the vertical path may be dusty with paper dust or worn pick up & feed tyres. There is also an issue with the feed clutches in the paper pick up drive unit which can fail & have been upgraded.
Secondly, if the paper is Z folded at the registration rollers but before the fuser then it could be the primary bed drive gear. This gear also drives the secondary belt unit located in the right hand door assembly.
Hope this helps.
Dave.
Jan 11, 2017 | Sharp Mx2600n Color Copier, Printer,...
Paper jam in Toshiba Tec
Check length of label and type of sensor used and check the sensors
Apr 02, 2013 | Toshiba TEC B-472 Thermal Label Printer
B-sx4t keep paper jam, i was replace the media sensor ,sensor cable and mainboard but still paper jam.Any one experience this?
Paper jam:
- The label is not correctly declared.
- Callibarate the sensors (5 sensor adjust) diagnostics menu
- the silicoe support is too thick.
Dec 05, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
We have a TEC BSX4T laser printer that is not printing correctly. Once you type info in..press print..the printing becomes progressively off centered with each successive label. Someone suggested the...
Plce the media guide correctly and check that the roll is centered correctly. Else you may have a problem with the alignement of the head on the platen.
Aug 25, 2011 | Toshiba TEC B SX4T Printer
Hello, where are a reseller of toshiba labelprinters type SX4. One of our customers has problems with printing labels. The errormessage on the screen of the labelprinter is: INLINE B-SX4T U5.0 and...
Well at my old company we use to get our's fixed and replaced from toshiba TEC in London.
Campus 300, Spring Way, Maylands Ave Ind Est
Hemel Hempstead, Herts, HP2 7GG
United Kingdom
info@toshibatec-eu.co.uk.
(0)870 890 7200
Aug 17, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
When i print several labels they are not aligned
Check the size of the label and the detection type selected
Oct 21, 2010 | Toshiba TEC B SX4T Printer
Sx4t labels gap setting
1. Press the [PAUSE] button. The display shows the printer is in PAUSE mode.
2. Press the [PAUSE] button again. If the display shows TRANSMISSIVE then release the [PAUSE] key.
3. Press the [PAUSE] button again. Labels will now start to feed through the printhead. After 5 or 6 labels have gone through, release the [PAUSE] key.
4. Press the [RESTART] button.
The printer should now be on line and if you press the [FEED} key, 1 label should be fed through.
Aug 21, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jams
Check solinoid transformers that controls opening and closing of paper handling trays. Check and clean sensors from in and out of paper path. Check and clean paper rollers or heat rollers for dust and paper remains pieces. Please determine when is the paper jams occurs. Hope this gives you hints.
Best regards,
Rosener
Feb 05, 2008 | Lexmark E238 Laser Printer
130 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
matt
matt
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
