Question about Daewoo F227B Monitor
My 6 year old Daewoo F227B began to fade yesterday and go a bit blurry. Is there a fix for this or do I need a new monitor. My computer is about the same age.
    Master:
  • 328 Answers
There is a fix for it but you won`t be able to do it yourself unless you have an idea of electronics but don`t worry because fixing it on the market won`t cost you a lot no replacements he will rotate something like focusing element inside it calibration
Posted on May 25, 2011
  • 1,179 Answers
The back lighting which is made up of a fluorescent light array, dies, as you have experienced. The picture in most cases can still be seen but it is very faint. Yes it can be repaired.
Phone around to get an idea of cost, you will have to decide which option sounds good to you. With regards to the cost of repairing or the cost to purchase a whole new monitor that is bigger and has a warranty.
You may find that a new monitor is relatively cheaper, remember that the monitor is not to be thrown in the bin.
Take care!
damnor01
  • damnor01
    damnor01 May 25, 2011
    Use the keys on the monitor to increase the brightness, it might be that the sreen is set to a low brightness level, it's just some-thing to check.
    Thanks again!
    damnor01
Using the contol buttons on front panel
You did not give a lot of info in this.
was the monitor old (many year) did it happen slowly or not.
is it even on all surfaced or darker on one side?
faded : no contrast or darker?
From the point vue I get, seem to be the neon lamp one maybe shot or not working a 100%
with year, the neon lamp loose brightnest. they even get yellow a little bit (if you compare a new monitor with an old one (white area) the old always fade in the yellow. )
Jan 03, 2014 | Dell Computers & Internet
Vertical blue lines in the monitor
try disconnecting the monitor cable and fixing it back.
Mar 02, 2012 | Daewoo F227B Monitor
I am not getting anysound from the speakers
This monitor has integrated speakers so therefor needs an audio cable to plug in from your computers Audio Output Socket (usually green color) into the monitors audio input jack. It needs a stero type plug for right and left sound. Have a great day.
Dec 05, 2010 | Daewoo F227B Monitor
Don't know how to decrease the brightness. It's straining my eyes. When I push the front bottom Menu button, a rectangle appears with the word Brightness, but I can't find how to decrease it.
Here is a manual for a Daewoo Monitor. On page 3 it indicates that there are buttons that show a right and left arrow above it. When you have the brightness menu highlighted press the left arrow button to decrease the brightness.
Sep 29, 2010 | Daewoo F227B Monitor
Vertical n horizontal ic
Are you asking about this LCD Daewoo (F227B) monitor? LCD monitors do not use Vertical/Horizontal IC like the CRT type for the H/V Yoke.
What is the problem with the monitor?
Common problem with LCD monitor:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Daewoo F227B Monitor
Daewoo w9zq 19"tft power light flashes but no screen :s
Open it up and check for bad caps in the power supply first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Daewoo F227B Monitor
Monitor does not come on and power light slowly blinks.
there are no signal output off your pc check your pc
Jul 10, 2009 | Daewoo F227B Monitor
I'm trying to service a Daewoo Monitor f227b
The slot with the K on it is a Kensington lock, it is an anti theft lock and does not affect the disassembly. Most monitors can be carefully prised apart as they are only clipped together.
Sep 27, 2007 | Daewoo F227B Monitor
Daewoo monitor
If you know a little bit about electronics, then you can find or buy a multimeter to check the output voltage of the AC/DC power adapter (if it uses one, sometimes the converter/adapter is inside the monitor). In order to get a voltage reading from center "hole" of the end of the power cord, use a paper clip (thicker paper clip if you have it). If the converter voltage is good, then this monitor might be a warranty return candidate. Hope it's only a power adapter problem (you can find a replacement on Ebay) ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Daewoo F227B Monitor
Daewoo F227B Monitor Logo
69 people viewed this question
Top Daewoo Computers & Internet Experts
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
