Question about Electric Eyeware Eleuke Blue MP3 K-Series Concert Ukulele
I just went to change the 9v battery in my eleuke ukulele and i was a bit distracted and accidentally put it in the wrong way. now the electronics do not work. does the ukulele have a fuse which i blown or have i fried it???? can it be easily fixed?
  • Electric Eye... Master
  • 5,603 Answers
There is no fuse... SOMETIMES the battery contacts get bent when battery is put in backwards due to the shape and size of the two connections. Verify the contacts in the uke are OK. Beyond that have a COMPETENT electronics person check it out. Often these have a protecting diode that prevents damage electronically.
Posted on May 25, 2011
Replacing the battery
It is easy to replace the battery in your Washburn guitar.
The battery compartment is located where you plug in an instrument cable to your guitar. Simply open it and take out the old battery and put in a new 9V. battery.
Regards
Sep 05, 2014 | Washburn WD10SCE Cutaway Acoustic-Electric...
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
When i plug my morley abc switch into 9v power from my visual sound one spot, to light the LEDs, it doesnt work, and it disconencts power to everything else on that daisy chain power. what's wrong. the...
Probably backwards polarity. If thing works on the battery, they MAY have wired it wrong. Should be an easy fix as circuitry is as simple as it gets. Have a person adept at electronics check it out.
Jun 28, 2011 | Morley ABC Pedal Switch
I seemed to have blown a fuse, in my danelectro tuna melt pedal. i just need to know what component to get and where to get it if possible. joe
No fuses in these. If you have connected a wrong adapter, be it an AC, too high voltage, or wrong polarity, take it to a repair shop unless you are electronically adept.
Jun 23, 2011 | Danelectro Tuna Melt Tremolo Guitar Effect...
I'm not sure how to put the string swing ukulele hanger inthe wall!!
It should come with mounting hardware, including screws and anchors. You'll need to:
1. Locate a stud in the wall.
2. Position the hanger where you want it.
3. Mark where the screw holes are.
4. Using a 1/8 in. drill bit, drill pilot holes on the marks you just made.
5. Put the hanger back up to the holes, and insert the screws.
If you have to use wall anchors, these should go in after drilling the pilot holes, but before screwing down the hanger.
If you need any clarification, let me know!
Hope that helps!
Feb 09, 2011 | String Swing Ukulele Wall Hanger w/ Wall...
What are the names of the individual strings on the ukulele? A B C etc?
the bottom string which is the highest plays an A then moving up the strings from there, but down the register they go E, then C, then G, but the G should be just one whole step below the original A.
Dec 25, 2010 | Ibanez UEW10QM EW Concert Ukulele -...
I plugged in a wrong adapter to MT-2 i think 12 v. it should have been 9v now it doesnt work is there any way to fix this problem?
Normally the 12 volt supply would NOT damage the unit UNLESS it had the wrong polarity or was an AC type.
Likely damage if these were used is confined to a few small electronic components where the power copmes into the unit.
Repair the unit before putting correct supply as you could damage the correct supply if those parts failed a certain way.
Aug 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
My boss dd-3 pedal only works with a 9v battery. When I hook it up to the 9v apaptor, (a boss) it freaks out and does nothing. Can you help? Everything seems solid. the jack doesn't wiggle or anything.
You will have to test the adapter with a volt ohm meter to make sure it is putting out the proper voltage. It should be as close to 9 volts as possible. Also make sure that thehole in the plug is negative and the outside is positive. Is it the right adapter? I don't have a schematic for this model but www.schematicheaven.com has one for a DD-2. Hopefully they haven't changed too much. If you decide to repair it yourself, check the adapter first then check for a bad solder joint where the adapter plug is soldered to the circuit board. Hope this helps somewhat.
May 14, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Electric Eyeware Eleuke Blue MP3 K-Series Concert Ukulele Logo
209 people viewed this question
Top Electric Eyeware Music Experts
Michial Gueffroy
Are you an Electric Eyeware Music Expert? Answer questions, earn points and help others
