Question about Garden
John deere lt133 will not charge battery runs for a bit then dies
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
  • 138 Answers
SOURCE: The charging system on the mower will not charge the battery up
The first thing to check on this machine is your voltage regulator try bypassing the voltage regulator to see if the alternator starts charging, it would be better to check your charging system with a voltmeter so that you know what the exact input and output in the electrical system.
Posted on Sep 23, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: where is the solenoid on john deere tractor model
Its just below the battery.We replace alot of solenoids on the LT series.Common problem.
Posted on Nov 14, 2009
How to adjust lt133 clutch john deere lawn tractor
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere
May 28, 2017 | John Deere Garden
How to adjust a clutch on a john deere lt133 lawn tractor
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere
John deere lt133
Engine oil does a couple of things, lubricates and cools. Your crankcase probably takes about 2 qts. Fill it to full and park it over something clean to see if there are leaks.
For your engine to run it needs fuel and air. If the engine is dying, more than likely you have a fuel/air issue. Check your fuel lines for leaks, replace your fuel filter. Clean or replace your air cleaner. Make sure your tank cap can breathe, so air can replace the gas going to the engine.
Jul 19, 2014 | John Deere Garden
Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Jul 16, 2010 | John Deere Garden
Garden Logo
247 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
