The machine do not spin,on the other sequence its o.k. I have replaced the capacitor, but the problem is still there.So I need the schematic diagram in order to solve the problem. Thanks in advance.
  • 1,056 Answers
I dont think that is an electrical problem. Check if there is a peice of small clothing lodge inside the pump that is keeping the drum from spinning.
Posted on May 25, 2011
  • legaidonald4 May 25, 2011
    Thks,I ll try it tomorrow.
    We are at 21.30 @ mauritius.
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Commercial quality washer, # AR150157P
Please check the output to the motor from the control panel and if there is not output then the sequence within the processor has failed. It can be a fault in the memory or a fault in the processor IC.
Also check the motor drive to see if the shaft is jammed and also the capacitor.
Jul 03, 2012 | Washing Machines
Washer wont spin or agitate
sounds like you got current, but it won't engage.....the belt could have come off
Apr 22, 2012 | Maytag Washing Machines
Not draining and no fast spin,sequence lights not moving through the sequences through the cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Hotpoint Washing Machines
Slow spin cycle
there is a starting capacitor for the motor once it has a leaked the motor will spin slow replace the capacitor.buy a replacement capacitor of the same rating.good luck!
Apr 09, 2011 | Washing Machines
Washing machine spins but wont drain
Spinning is from one motor. Draining is from a smaller motor ( pump). The problem is from the pump. Accessing from the back after removing the panel, unplug the pump connectors to measure resistance to see if there is continuity. If not then the pump needs to be replaced. If there is then need to trace the schematic back to the controller. The schematic is in a small plastic bag attached at the time controller.
Jan 09, 2010 | Tecnik TKL9260 Front Load Washer
Fisher paykel wont spin
Parts that can be responsible are motor and motor control unit, the motor has a starter capacitor built inside the motor assembly, or in the motor control unit .
I do not have diagrams for F&P , call them back and ask for schematics to locate the problem.
May 20, 2009 | Fisher Washing Machines
Alll the water does not spin out , clothes still wet
Your clutch is wearing out and needs to be replaced. It will only get worse. Ive included a schematic , part # is 285785. #5 on the schematic. Let me know if you need more help, thanks dave www.washermd.com
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Whirlpool mod#LLR6144AQO electrical issue
If you have power at the console where the power cord connector connects to the harness then make sure all wire harness connections to the timer are tight. If so, then something must have happened to the timer as nothing else will keep the machine dead in fill and spin.
Nov 30, 2008 | Whirlpool Washing Machines
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
