Are you using a DVD+RW disk? Unlike DVD-R, DVD+R and DVD-RW disks you cannot finalize DVD+RW disks on the Magnavox MWR10D6 DVD Recorder. Instead you have to make the disk compatable [Make Edits Compatible], this allows you to close the disk and play it on other DVD players.
go to: Setup ==> Edit Disk ==> Make Edits Compatible ==> Yes
Other than this nothing else comes to mind to troubleshoot this problem. Hope this helps.
MWR10D6 use the set up button on the remote - go to edit disk - finalize disk - yes - good luck
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
the edit in the menu isnt lite up like the rest of the choices ,so i can finalize my dvd ,what can i do ,how do i finalize... thanks
