Question about Microsoft Wireless Laser Mouse 5000
How do I open the mouse to change the batteries
    Problem Solver:
  • 12 Answers
Hello cmaryclaire,
If you look at the under-side of the mouse, you should see a rectangular area (similar or the same as the picture below) with a small clip. All you should need to do is use a finger, push on the clip and lift. This should reveal the battery compartment.
Posted on May 25, 2011
How do I change the battery for my logitech cordless mouse? Can't find opening for battery....
hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
Jan 06, 2011 | Logitech Cordless Mouse
Change battery in wireless mouse?
yes - change them - there is a screw cover - unscrew the retaining screw - Philips screw type - and replace the batteries
Dec 08, 2010 | Logitech Cordless Mouse
How do I replace the battery on my cordless mouse
Step 1 change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); }); Exposed batteries of a wireless mouse Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
Step 2
  1. change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  1. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Good luck.
May 09, 2010 | Logitech Cordless Mouse
How do i change the mouse battery?
Hello Dear,
Usually Cordless mouse comes with rechargable batteries, that you don't need to change so frequently, if you charge them at regular intervals with charger provied along.
However, you can change the batteries, by turning the mouse upside down. Now you see the battery compartment, just open it by pressing the lock down. Now pull down the old batteries and replace with new one. Just make sure that the new batteries are placed in the same way as the old one.
Thanks
Mar 17, 2010 | Logitech Cordless Mouse
How do I open the mouse to change the battery?
Turn the mouse upside down. push the tab and open door. pull out batteries and replace with same type. make sure batteries are loaded as per diagram on inside of compartment
Nov 21, 2009 | Logitech Cordless Mouse
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
May 27, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft optical notebook mouse 3000 battery change
Simply push the silver oval button below the word "Microsoft" and the cover will spring open.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Hi I have cordless Logitech mouse that was working until yesterday. Not sure if I have to change battery. If this is the case, how/ WHERE do I open the mouse to change the battery?
The battery holder is on the top of the mouse directly under the palm of your hand. simply push the surface away from the mouse buttons and it should pop open.
Nov 27, 2008 | Logitech Cordless Mouse
Changing the batteries
I'll give you info on how to change batteries in two different type mouse units. Not sure what type you have.
The normal way to change batteries on a mouse is to turn it over and open the little door on the bottom The compartment holds 2 AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 16, 2008 | Logitech 931150 Mouse
Openning battery comparment
Underneath the mouse the little compartment that holds the usb stick can be removed to reveal the battery compartment.
Jan 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Laser Mouse 5000 Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
