Question about Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher drain blocked. f11 message. Help!!
    Novelist:
  • 251 Answers
Hey there - if you have not read any of the post on here - the pump could be serviced from inside the machine, empty trays out, revoe the steel mesh on bottom with a lock lever where the drains is, under here you will see a steel spring like clip, move & pull the housing under it, then the pump impellar is there - just clean it out carefully - assemble or close door run a drain for 2-3 secs, assemble . should be good to go.,
Posted on Jun 17, 2011
F11 blocked inlet/drain
f11 error code says in the manual
Drainage fault
Water present in appliance and is not being drained off. The display shows
Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning. Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
this is usually caused by a blockage in the drain but can also occur from other circumstances as listed above you can also see this at this link as well http://appliancehelponline.com/miele.html
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Jun 07, 2011 | Miele Dishwashers
Miele Optima dishwasher. Doesn't drain, and display says "F11"
check the drain solenoid valve if working properly or check if voltage is present if you press the drain switch.
Aug 12, 2010 | Miele Dishwashers
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
I have a G1220SC model. F11 shows on the panel,
F11 is a drain error.
Water outlet restricted.
** Check for kink in the drain hose.
** Clean the filter combination. (p.41)
** Clean the non-return valve (check valve) (p. 53)
** Check/clean the drain
Unplug the machine.
Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
Plug in2_bing.gif the machine and re-try.
THIS MANUAL
may not be for your model - however it will give instructions on some of the steps above.
If all checks out - the pump will need replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 25, 2009 | Miele Dishwashers
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Drain filter F11
Unplug the machine.
THIS MANUAL
Jul 07, 2009 | Miele Dishwashers
Miele dishwasher did not drain. Discove
Yes - the dishwasher drains into the disposal - if the disposal is blocked up - it will hamper the dishwasher draining.
Nov 15, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Got a Miele G2220sci dishwasher unit, getting an undocumented error code of F19 with flashing lights, help! what does F19 mean? WONT DRAIN. PROGRAM FINISHES WITH F11
Hi again,
At your convenience would appreciate how the Miele dishwasher is now?
Hope this be of more help/idea in the future. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Dishwashers
CODE F11 ON MIELE 1220 SCH
I disconnected the drain where it enters the S bend from the sink. I found the nozzle into the S bend was blocked. I probed this with a screwdriver and cleared the blockage then I reconnected the drain. I turned on the dishwasher again and the F11 code was cleared. The dishwasher operated ok again.
May 14, 2008 | Dishwashers
Miele 24 in. G665 Built-in Dishwasher Logo
900 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
