Question about Home
Hi. I am having trouble with jacuzzi hot tub. When i turn it on the led comes on for 10 seconds and clicks off. When I unplug the sensor the light stays on. Could it be that simple? Thanks
  • randy186 May 31, 2011
    Yes, That worked. Thanks
  • 456 Answers
I would certainly change the sensor before checking anything else.
heat, vibration and moisture can all affect the sensors on these units.
it is possible that the control board has developed a fault, but the sensor has to be the first thing to do.
fortunately they are usually fairly cheap, and most just pull out and insert the new sensor.
please feel free to ask again if a new sensor does not sort the problem.
hope this helps.
Posted on May 25, 2011
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
The water will not heat up. How can I trouble
the last time I looked at heaters for jacuzzi tubs they are designed to keep the water at the temperature you filled the tub and not heat up the water from cold to hot.
Apr 04, 2010 | Jacuzzi Home
Trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Home Logo
122 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
