Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas
I have the below heater for my pool. I hooked it up yesterday and i have power to it i checked with a meter. looks like there isn't any power on the panel because i dont even see the water flowing on the panel when i should. i pressed the power button etc. what should i check?
    President:
  • Teledyne Laars Master
  • 1,378 Answers
Check the secondary side of the transformer...Line voltage in gets reduced to 24V across the transformer and if it failed you'll have 0 and a dead heater.
John
Posted on May 26, 2011
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
3/4 hp pool pump and gas heater won't run. Both are on a 30 amp breaker. power goes to the pump and heater but nothing runs
USE A VOLT METER , START AT THE BREAKER AND WORK YOUR WAY TO EACH DEVICE. THIS WILL HELP YOU TRACK DOW THE POWER ISSUE .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 18, 2012 | Pool & Spa
LLG325N Larrs heater wont stay running. Replaced the pilot assembly. It fired up for about 10 seconds and then quit.
You should have a flame sensor wire going to your pilot. Make sure that it is hooked up correctly. If the sensor isn't relaying flame to the control box it will think you don't have a flame and will shut off gas flow for safty reasons. So be sure the wire is connected and in good shape. I hope this helps.
Aug 14, 2011 | Jandy Laars Hi E2r Heater 350k Btu Natural...
I've installed a intermatic t101p201 which has a heater delay circuit - but can't get power to the heater through the delay switch when i turn the switch manually on - i haven't checked yet to...
Check that your pool heater supports optional fireman's switch
Black wires on firemans switch connect to pool heater. Power to fireman switch comes from pool equipment and not the timer.
If pool equipment does not support fireman, then cap off the wires.
Fireman switch turns off heater 15-20 minutes before turning off pump.
The purpose is so pool equipment lasts longer.
You can buy the fireman's switch separately, but if this is new timer, then switch is probably good.
Open following link to identify fireman's switch and related parts for the timer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#fireman
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Intermatic HEATER DELAY SHUT OFF SWITCH...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas  Logo
50 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
