Question about Shimano Hg40 1134t Mountain Bike 8speed Cassette
Ow do the cassettes conect to the back wheel screw on or push ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
Cassettes fit on a spline with a lock nut to keep them there, the spline is also the ratchet.
Older bikes had a ratchet/sprocket assembly which screwed onto a threaded hub
Posted on May 28, 2011
I replaced fuel lines on 323L but may have crossed something. looking for diagram of fuel system to be sure of correct location
The fuel primer pulls fuel from the metering side of the carb, into the bulb, and pushes it back to the tank, so the hose from the fuel tank with the filter on the end goes to the carb conection nearest to the pump cover held with a single screw, the other conection on the carb goes to the shorter of the two conections on the back of the primer ( suction side ) the longer conection on the primer ( pressure ) takes the fuel back to the tank.
Jun 16, 2011 | Husqvarna Garden
Where does the fuel line from tank with filter fit on walbro carb.also where does the primer line go?
The fuel line from the tank fits to the main fuel inlet on the carb ( the inlet nearest to the alloy pump cover secured by a single screw), the other conection on the carb has a pipe that conects to the shortest conection on the back of the primer ( suction side ) a pipe then goes from the longer conection on the primer ( pressure side ) back to the tank, it just pushes into the top of the tank.
So to recap the primer pulls fuel from the carb, and dumps it back into the tank.
May 09, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to conect fuel lines to poulan chain saw 2375 Le
The hose coming from the fuel tank with the filter on the end goes to the fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, now take a hose from the other conection on the carb to the shorter ( suction side ) conection on the back of the primer, take a hose from the longer conection ( pressure side ) on the primer back to tank, this just pushes into the tank, just remember that the primer pulls fuel from the carb and dumps it back to tank.
Apr 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
I have several 30+ year old recordings. Sound quality is fine BUT a few of these tapes have come off the hub and need to be re-attached. Any suggestions ? john30662@yahoo.com
its sounds like you have the real FUNK (the good stuff) music...
John, if you still have the casing for these little cassettes I will tell you how to roll these tapes back onto the hub. you will need some crazy glue and a tiny phillip screw driver...its operation time, unscrew the 1st tape that is off the hub..when you open it make sure that tiny metal w/cotton pad is intack now the tape is already off the hub right (take the hub and push side ways that small piece on wheel like...now straighten out the tape on the other side of you...put 1/4 or 1/8 of in onto the hub ..do not try to snap the tiny piece back in, slide it in sideway on top tape..once this done ...no tape is sticking out right...place the tape through its slots (so it can run smooth) we about to put it back together make sure the metal w/ cotton pad is still in its place.... screw it back together (crazy glue is only for the tapes casing that dont have screws or that cracked)....now continue the process for the rest,,,,yes I have done the same process for micro / regular cassettes/ VHS and the those 8's. like me I still have my tapes too but a suggestion its a little time consuming but you should either put these tapes on portable hard drive (500 gig) or burn it to CD...
hope this helpful
May 12, 2010 | TDK 60 Minute Micro Audio Cassettes...
I have a shimano tourney deraileur with sis index. what does the small adjustable screw which is off by itself adjust. the other two screws are for the upper and lower gear stops.
Is it a long screw running into the derailleur hanger? This sets the distance from the cassette to the jockey wheel. You use it to pull the jockey wheel away from the large cassette cog if the chain is having trouble clearing it. You'll know if it is happening because the bike will be making more noise in the low gear and it will sometimes want to skip out of gear.
Sep 13, 2009 | Shimano Cycling
Daisy wheel will not stay on wordsmith 100
CHANGING Changing The Ribbon Cassette 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette. 3) To insert a new cassette, place the back end of the cassette on the cassette holder on the carrier and gently press down on the front of the cassette unit it clicks into place. 4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon. 5) Presss the CODE + = (SETTING) key.
Changing The Print Wheel 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) You will see a lever on the right side of the carrier. Pull this lever toward you and lift out the daisy wheel. 3) Place the daisy wheel into the slot with the characters facing the platen. 4) Push the lever back into position. 5) Press the CODE + = (SETTING) key.
It appears as though you have something that is preventing the print wheel from being locked in place by the release lever. It should make a snapping or similar noise when it is locked down.
Dec 10, 2008 | Smith Corona Wordsmith 100 Typewriter
Canon md101 manula eject
yup there is sort of... you take a jewelers flathead screwdriver and push the spring back on the lens side of the cassette holder. and then on the other side there is a little hook that latches over a bump that locks it in place, you push that down and it will unlock... from there you might have to take the extremely small screw out at the top and remove the whole cassette tray...
Jun 09, 2008 | Canon ZR100 Mini DV Digital Camcorder
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
Shimano Hg40 1134t Mountain Bike 8speed Cassette Logo
74 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
