Question about Microsoft Windows XP Home Edition
Virtro memory My computor wont open alot of files and programs because it tells me my virtro memory is to low how can I i get more virtro memory?
  • jesscuz Aug 21, 2008
    thank you for your help
I want to be an expart in MS Excel
Posted on Aug 23, 2008
  • Microsoft Master
  • 2,794 Answers
Go to the control panel. Go to system. Go to the advanced tab. Under performance, press the settings button.
Press the advance tab.
Below virtual memory is a change button. Press that.
Press the custom size radio button. press ok.
It will ask you to restart your computer.
Make sure you have plenty of free space on your drive as well.
Posted on Aug 16, 2008
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Why thers always prompting in my screen of low memory disk?
open the task manager to see the ram-usage. This series do not have alot of memory, therefore several tasks running at the same time can make this message pop up. You might have to many startup programs activated, change settings to start programs manually.
Oct 08, 2013 | ASUS Eee PC 1000H Laptop
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
My computor does not delete files from the hard drive even though it says it does. May hard drive keeps building up used space and I have deleted lots of programs, but the space is still occupied with the...
your computor may have been infected with a virusshutdown computorpower on while tapping the F8 key until you see advance boot optionchoose safe mode with networkingobtain HijackThis from trendmicro.comrun and kill all HJT tells youreboot computor
Jan 24, 2012 | Microsoft Windows 7 Home Premium Family...
How do i downloag music stored on a file in the computor to my card to put in my phone. I put the card in the computor and it dont tell how to use it
first insert your card to computer, use card reader your card will show as removable disk
if the card was show, open windows explorer, search music that you wan to download to card
select the music file that you want to insert to card
right at file that you select then click copy
after that go to removable disk drive, open it, open the folder music/sound
at that folder right click and click at paste
and you done the process download from computer to card
eject your card from your computer
insert your card to the phone and you canplay music at your phone
i hope this helpful
thank you for using fixya
Feb 07, 2011 | SanDisk 2GB microSD Memory Card
Over a couple of months my Toshiba Satellite Pro Laptop keeps telling me I have very low disk space. Ive removed all my pics, music and alot more! it is pratically empty now! I regulary have to run Disk...
'Low Disk Space' Could be talking about your virtual memory. Sounds as if your RAM is experiencing problems and your Virtual Memory cache is not high enough.
Jun 16, 2010 | Computers & Internet
My laptop keeps coming up with low memory!
Low memory usually refers to the RAM. Low space refers to the Hard Drive. You might have too many applications/programs running at the same time on your laptop. Or have an application or program that is using up too much memory. Viruses/Spyware sometimes do this to put your computer in a state that is not usable.
So what you can do is add more RAM. And check your "Task Manager" for applications and/or programs that is using too much RAM. Look under the column "Mem Usage"
Aug 17, 2008 | Toshiba Satellite A70-S249 Notebook
My phone htc p3450 touch shows low memory
HTC gives the same problm if u use internet alot... try deleting the cache n cookies n all the history every time u use the internet and try not to save anything on the phone memory... helpz alot
Aug 05, 2008 | HTC Touch P3450 Smartphone
Product won't download to my computor
Mine's doing the same thing. I have tried loading it onto two different computers. I was going to format it and try just using it as a USB storage device, but i don't think it would display the pics then. I'll probably be returning it.
Dec 25, 2007 | Innovage Mini Flip Phone 1510255
Microsoft Windows XP Home Edition Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
