Question about Whirlpool Aquatic Infinity 1 66X66X25 White AI1INF6666
Our heater broke for our Aquatic AI1INF6666 Infinity hot tub. Is there any way of replacing it. Where would I buy the parts?
2 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Aquatic Airjet studio 34 seeping water from sides
issue with the Mfg process. needs to be exchanges with the factory. it cannot be fixed and expected to be ok for the life of your home.
Posted on Nov 15, 2009
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
Need to figure out how to clean out the black stuff that comes out when we turn on the air jets
You need to get some jacuzzi cleaner solution or hot tub jet cleaner solution fill the tub with the solution and follow directions to clean them out needs to be done every couple months IF THIS HELPED PLEASE VOTE FOR ME
Aug 26, 2011 | Whirlpool Aquatic Infinity 1 66X66X25...
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
The foam instulation in my hot tub cover broke from heavy water
Pretty hard to repair. If the outer shell is intact, just use it. You may open the cover and take the foam out, duct tape it and reinstall. Other than that, you have to buy a new one. Good luck...Lee
Sep 21, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
HELP WITH MAYTAG DRYER DE712 DRYER HAD NOT BEEN USED FOR WEEK NOTICED THE TUB WAS HOT AS IF HAD BEEN IN USE FOUND A HEATER COIL BROKE AND AM REPLACING HEATER BUT DO I NEED TO REPLACE SELECTOR ALSO...
Hi, The element broke and shorted out against the metal on the dryer. The thermostat did not cause the element to break and will still be ok. You replace the element and you should be ok.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 05, 2009 | Dryers
Foam in hot tub cover broke
The foam in there is available at most insulation or drywall supply houses. It is used for insulating concrete walls, the cover is probably 3 inches thick so you may have to buy 2 sheets to get the thickness you want. The only issue is the cost of the foam may not be much less than a new cover.
Mar 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Nov 11, 2008 | Sport & Outdoor - Others
Whirlpool Aquatic Infinity 1  66X66X25 White AI1INF6666 Logo
27 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
