Question about Ricoh Aficio 1035 Copier
Ricoh aficio 1045 - SC541 - Ricoh Aficio 1035 Copier
  • Ricoh Master
  • 525 Answers
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
• Power supply board defective
Posted on May 27, 2011
5 Suggested Answers
  • 183 Answers
SOURCE: Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Posted on Jan 13, 2011
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
M2Tech1
  • 313 Answers
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
Service call sc541
change the fusing thermister
thanks
Nov 26, 2015 | Ricoh Aficio SP 3510SF
Jan 11, 2011 | Ricoh Aficio 450 Copier
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
RICOH AP410 HAS A SC541 FAULT
sc541 is the thermostat, in the fuser section. i would personally change both the thermostat(s) and the thermistor(s).
Jun 20, 2008 | Ricoh Aficio AP410N Laser Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 Copier Logo
553 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
