Question about Acer Aspire One PC Notebook
I can't connect to the internet anymore. i've tried the connection settings but it doesn't respond or recognise the icon when i click it
  • bulldog May 25, 2011
    what internet connection type are you using? are you getting message page cannot be displayed?
  • 386 Answers
First thing you can do is a ipconfig /release /renew
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Please Rate;)
Gary
Posted on May 25, 2011
Cannot connect to internet
Try these two methods below.
Method 1: Check your local connections at network and sharing center, if there are two enabled or active networks. If there is two active networks, click on Local Area Connection Link (for windows 7) on one of the active networks and disable it. Now right click the internet icon on your taskbar and troubleshoot problem. If it doesn't resolve the problem, you will have an option to resolve the problem as Administrator.
Method 2: Go to local area connection status on an active network, click properties then double click on internet protocol version 4 and make sure that "Obtain an IP address automatically" and "Obtain DNS server address automatically" are checked then click OK.
If it doesn't solve your problem. Please contact me so that I can assist you more further.
Sep 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
My sound card isn't recognised
  • no computer stated.
  • no operating system stated
  • or of connected to the internet
internal speakers or external?, you never said.
does the device manager show the sound chip? it must or the HP drivers are missing, (some take more lower level chips working first)
(yah complex and in the correct order installed)
with no red or yellow marks, ? DM colors>
be on the internet , right click, that sound chip and click update driver? curing said driver errors?
my guess, is there are other HP drivers missing or wrong.
Get the HP recovery kit for this LT? reinstalled unstated windows?
it could be virus infected and if it is, you will never get it right,
unless fresh loaded .
If this is XP it is a virus magnet, for now and eternity..
see this tag, see that name and number here, what do you have.
this is a service tag seen on all hp gear.
Mar 15, 2017 | HP Computers & Internet
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
Im using yahoo messenger version 11 .i cant sign in anymore .. other website like facebook n search are okay except in yahoo ..what are solution of this problem..pls help
i got the same problem with my ym 11 too.. but honestly looks like its ym problem that it may just work whenever it want to.. :( but try this.. open Yahoo Messenger click on "Messenger" (on top), choose "Connection Preferences" select "Connect via Proxy Server" try to log in ..
if it doesn't work put it back to the original settings, same instruction go to YM, click Messenger then Connection Preferences select "Connect directly to the Internet".. this time try to disconnect your internet connection first.. and then with your YM open enter your username & password but dont click "connect" yet.. connect to internet & log in to ym (you should click "connect on ym right after a second you are connected to the internet)
Sep 10, 2011 | Yahoo Messenger
Hello sir i am facing a problem in a Dlink 1016d how to connection to netgear through a LAN connection
use the LAN port at the back of your PC and connect using a patch cable (cat 5 or 6 cable)
Sep 01, 2011 | D-Link DES 1005 Ethernet Switch
I've recently re-installed Windows XP on the machine, but the computer doesn't respond to a LAN cable anymore. The Ethernet Controller is missing I think. Because I've tried "Set up a Home...
Hi, you can seach for drivers here at MSI:
http://www.msi.com/service/download/
Just type in the full machine number and click on search.
The full number is at the bottom of the machine.
Remember to select your operating system.
Aug 31, 2011 | Intel Motherboard
The light for Internet doesn't come on and thereisn't a globe icon on the bottom of the monitor. I can't connect and I checked with Verizon and it's not on their end.
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online.
However, if it doesn't, click on 'Tools' again and then click on 'Diagnose Connection Problems' and follow the instructions.
All the best
Ben
Jun 16, 2011 | Linksys RangePlus WRT100 Wireless Router
I have an acer aspire one and a wireless internet device from verizon. It connects but it doesn't connect as far as letting me on the internet anymore. My laptop said that I needed to change the...
you need to right click on the network icon in the bottom right corner like in the one picture I have Included and then click on network and sharing. Once this opens you should see active connections this is where you click to change it to home like in the picture i have includedecaywood80_2.jpgecaywood80_1.jpg
May 17, 2011 | Computers & Internet
My Acer One does not connect to the net anymore. Network connection does not respond. Internet connection symbol has even disappeared...
Go to your control panel and click on the network icon and follow instructions from there to restore your network
Mar 19, 2011 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
