Question about Toshiba 32A33 32" TV
Toshiba CF3062A 9150
1/4 the way down on tv screen i have 2 rows of small white dashes and then a long set then even longer lines and the top has some shadowing effect of what is on the tv any help - bought at garage sale cant return want to fix thank you rhonda in kc
  • 1 more comment
  • cjballer19 Dec 01, 2008
    tv has a straght line on display color is white
    tv has a line of the show on it
  • smandry Dec 29, 2008
    I have a shrunken vertical raster, about 40% of full size, with very bright scan lines at bottom. It gets near normal size after set warms up, but is still distorted near bottom of screen. Looks like a vertical sweep problem, but I have no schematics, or repair manual.
  • 525 Answers
CAN YOU SEND ME THE PICTURE OF YOUR IMAGE TO MY EMAIL ADRESS :
semirengeee@yahoo.com
Posted on Oct 20, 2008
I have a CF3062A. Picture has collapsed into a
In the old days that means your "flyback transformer"needs to be replaced.
Take it to a TV tech or junk it and buy a new one. That might be cheaper.
Jul 19, 2010 | Toshiba Televison & Video
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Thin horizontal line with a Toshiba CF3062A
This is a problem with the vertical circuit that is usually a defective vertical IC. This part costs $10-$20 and is easily replaced. Sometimes there are capacitors in the same circuit that need to be replaced as well. Dan
Jun 09, 2009 | Toshiba Televison & Video
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Toshiba CF3062A
check capacitors location# C305-values 2.2mfd@50v,C342,2.2mfd@50v....
Jan 10, 2009 | Televison & Video
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Toshiba 27" standard def. TV
white narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Sep 13, 2007 | Toshiba 27A34 27" TV
White lines on screen
im sorry my friend I do not understand what a funny marrior is? LOL If your complaining about white lines at only the top of the picture, then I would say that your problem is with the vertical sweep circuit. Most likly a capacitor in the vertical preamp really small ones next to the jungle IC or the capacitors that are used as waveshapers in the vertical drive and output. If the entire screen is white lines then the screen drive is too high so back it down till the lines just disapear. if that wont turn down, theres a filter cap on the sweeop supply or the CRT socket board is bad. Good Luck
Oct 08, 2006 | Toshiba 32HFX71 32" TV
Toshiba 32A33 32" TV Logo
184 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
