Question about Camping, Backpacking & Hiking
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
    Novelist:
  • 172 Answers
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
Posted on Jun 02, 2011
  • Agls Jun 30, 2011
    Hello, I have the same Lantern and it has worked well for 4 years of many cub scout camp outs. Unfortunately, the charger that came with the lantern crapped out and I have been using the auto-charger. Doesn't quite do the job though. i purchased a 1200 mA AC to multiple DC charger and as you stated above am looking for the correct polarity. The appropriate symbols are not on the lantern at charging receiver location (ugg!). I can not seems to find the correct polarity on the web either. I tried calling Coleman but you just end up on the phone forever and nobody answers. If anyone knows the correct polarity, please respond and thanks in advance.
  • Conrad Jacoby Jun 30, 2011
    I do not have the exact spotlight that you have, so any suggestion I make based on my own Thor X light is really just an educated guess. On the other hand, because you have an auto charger that works with your spotlight, you can easily figure out the polarity on your own. Plug the charger into your car's 12v outlet, and then use a multi-tester to check the polarity of what's going to the plug you'd insert into your light. Put the red positive lead on the center and touch the black negative lead of the tester to the outside of the barrel plug. If you get a reading of somewhere around 12 volts, you'll need a center positive tip. On the other hand, if you get a reading of NEGATIVE 12 volts, you'll know that you had the leads attached backwards, and you have a center negative port.
    If you don't have access to a multi-tester, you might try bringing the car charger to a local Radio Shack and seeing if they'll test it for you. Back in the old days, this is exactly the kind of thing they'd do for free as part of getting you set up properly with a replacement charger / power adapter. Hopefully, it's something they still do (and know how to do).
    New Friend:
    Problem Solver:
  • 7 Answers
You can find good answers in b2cled.com
Posted on Apr 08, 2013
I am looking for a battery for my vector vec 138 c . I cannot find one anywhere.
is it a 12v ??? if so i have an extra 12v 7AH sealed battery its a hanger 9.. the same as what i use in my thor x 10million cp spotlight. if it will work for you im willing to part with it if it will help you out..
contact me at
matthew.swall@yahoo.com
Jul 27, 2011 | Vector Camping, Backpacking & Hiking
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
What volt and amp charger does the vec127y use
It uses a Class 2 Transformer to charge the battery. The input is 120V AC 60Hz 9W. Output is 12VDC 300Ma.
Nov 09, 2010 | Vector Spotlight - 1 Million Candles...
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
Spot light doens't work
The battery is probably defective, take the battery out and test it, it should be at 12 volts.
Feb 28, 2010 | RoadPro 1M Candle Power Spotlight 12V
New wall Charger needed
Depends upon the model, but most use 12v 500Ma batteries w/ a barrel-pin connector.
You can buy one here, or search this site for your model:
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
Sep 22, 2009 | Vector 1 Million Rechargeable Spotlight
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
Camping, Backpacking & Hiking Logo
2,982 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
