Question about Acer Aspire 5500 5570-2609 Laptop
I have the acer aspire and even though it shows i am connected to the network i can't get on the internet
SOURCE: acer aspire 5315 crystal eye webcam
Check first your webcam if its is installed properly... the message poop bcoz the system cannot find connected webcam its not acttualy about your connection to the internet..
Posted on Nov 06, 2008
  • 479 Answers
SOURCE: CANNOT DETECT WIRELESS NETWORKS
Please type services.msc on run option
2.Please check there will be a service named as wireless zero configuration if you are using XP otherwise the third last service in vista.
3.double clisck that and then stop after restarting the machine again go to same and start it by clicking start.
4.If then also the issue is not resolved please check with your hardware vender.
Posted on Feb 09, 2009
SOURCE: My acer aspire one mini notebook doesnt connect to internet
This will happen if you let the battery go completely dead. Some files become corrupted.
Solution:- Right click on Settings (preferences some models). Select 'Network' then double click on 'gFTP'. Scroll down to '.gconf' and double click. select and double click on 'system'. Right click on 'Networking'. Scroll down to 'Delete'. Left click on 'Delete'. Confirm 'YES'. Turn off the computer, then restart. What you have done now forces the computer to re-create the networking file. Your networking icon should re-appear on the taskbar. Note this is only for LINUX systems. - Good Luck!
Posted on Feb 25, 2009
SOURCE: i cant get into my internet settings !acer aspire
I know nothing about Linux and had the same problem. I found this on another site as I have been searching for an answer. Just finished as instructed and it has worked. Just in case I renamed the folder rather than deleting it! "Follow this then restart and everything should come back to normal. It took me 3 minutes and worked fine.
This is to find and delete the networking folder (which is causing the problem):
1. From the regular Aspire One options page, go to the Files panel
2. Click on the triangle to see more icons
3. Click on MyFiles, which opens a file manager window.
4. In the menu bar, select View->Hidden files, to show a tick in the box. You should be in the "My Disk:///" directory.
5. Scroll down until you find folder "gconf" and then click on that
6. Find folder "system" and click on that
7. You should now see folder "networking" listed as one of the folders.
8. DELETE IT! (Right click on the networking folder, and select option delete.)
I just restarted from here and the icon re appeared in bottom right the menu bar, I just clicked on it to set it up with my wifi signal and it did the rest itself. " Have fun and dont panic!
Posted on May 10, 2009
  • 6 Answers
SOURCE: cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Posted on Jul 14, 2009
Acer Aspire 4339 issue with home network connection
are you internet drivers installed?
try to connect your gateway first to know that your connected to your device
simply press start then type cmd (command prompt)
type ipconfig and you will see the DEFAULT GATEWAY then type that on yor web browser if you can connect ....
also try troubleshooting your adapter..........
open network and sharing center then go to the "change adapter settings" in the left pane then right click your adapter and select troubleshoot this
windows can find the problem and it can fix automatically
Nov 28, 2013 | Acer Aspire 4250 4251 4252 4253 4333 4339...
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
My acer aspire 5517 laptop came with a built-in wireless card. It works fine at home with my Belkin router, however, I cannot connect outside of the house to other networks. Currently I am away at a...
Your friend's network SSID (the name of the network) may be hidden. Ask your friend what the name of her network is, then enter that in manually and try to connect.
Mar 05, 2011 | Acer Aspire 5100 Notebook
I have a acer aspire 5570Z, unable to connect online...
Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
If you are using your manufaturers software then try using windows xp (or vice versa)
Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Problem's with built in wireless card
A friend of mine had a similar problem for whole 6 months until i uninstalled Norton. So if you use Norton Antivirus use this tool to remove it:
ftp://ftp.symantec.com/public/english_us_canada/removal_tools/Norton_Removal_Tool.exe If link doesn't work use this link: http://majorgeeks.com/Norton_Removal_Tool_SymNRT_d4749.html
Mar 10, 2009 | Acer Aspire 4315 Notebook
Can't connect to internet with built in wireless
Do you have Windows XP, and did you install Service Pack 3? If so, you may need to go to the wireless card's manufacturer's site and download an updated driver (or if not available, reinstall the original driver). SP3 puts in a file that is incompatible with many wireless cards.
Mar 04, 2009 | Acer Aspire 4315 Notebook
Cannot connect to internet
try running this command "netsh winsock reset" in your dos prompt. to go to dos prompt press the window key+r and type "cmd". then it will popup a new window. type the command and see if you can connect to internet. it might be a problem with spyware as well which infected the winsock or the network drivers. download combofix and run it.see if that helps u.
Dec 14, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
