Question about GE Spacemaker JVM1640SJ Microwave Oven
Display screen very dim - GE Spacemaker JVM1640SJ Microwave Oven
  • 3 more comments
  • opsahlr May 25, 2011
    Need part number for controller board for GE SPACEMAKER
    JVM1840WD001
    Also price and availability of controller board
    opsahlr@mac.com
    you have the wrong part number for my microwave oven it is JVM1840WD001. I believe that i need a complete controller board. Can you help to find the correct part number of the controller board and give me price and availability information.
    You continue to have the wrong model number for my microwave. It is a JVM1840WD001.
    your solution continues to have the wrong pn for my micro. Can i speak to someone by phone?
    YOU HAVE GIVEN ME THE WRONG ANSWER AND NOW YOU WAN TO CHARGE ME AGAIN. WHAT IS GOING ON?
  • GE Master
  • 43,501 Answers
The display board is going bad and will need to be replaced...
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on May 26, 2011
  • 4,323 Answers
Hi
It seems that the issue is with the membrane switch (part#15 in this diagram)...manufacturer part no WB27X10447 and is available at this link. The control board seems to be working fine so it seems that the board is fine. Hope this helps...please post back for further assistance.
Daniel
Posted on May 25, 2011
  • 3 more comments
  • Daniel Scott
    Daniel Scott May 25, 2011
    Alright then...you can buy all the parts from this link
  • Daniel Scott
    Are you alright?? The part link shows the parts for your model which is JVM1840WD001......
  • Daniel Scott
    Have you even checked the link?? At least check and read carefully before rejecting the solution
  • Daniel Scott
    I gave you the link for all the parts that your Microwave has....how can it be wrong with all the parts showing....
  • Daniel Scott
    The answer is right....don't know what you are looking at.....and dont know why you cant see the part...anyways thanks for rejecting again
  • 17,970 Answers
You may have a dim display or a fading display, or the circuit board may need to be repaired. They do these regularly for $39.95 nationwide.
If the display flickers but it does not affect how the microwave heats, then you don't need to worry about it. But if you are having display flickering and it is affecting the way your microwave operates, you may have a more serious problem in the microwave cabinet.
For microwave display and other control panel repair, see microwavedisplay.com.
Hope helps.
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
I have micro wave #JVM1790SK01 on the display panel the info is very dim is there a adjustment to make it brighter
There is not usually an adjustment. The dimness is normally caused by an exhausted display.
Oct 20, 2015 | Microwave Ovens
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
Microwave display dim
It's replaceable... but not worth it...
Apr 09, 2014 | Microwave Ovens
Display very dim
Unplug the oven for five minutes and plug it back in, if the display is still dim you most likely have a bad smart board.
Apr 07, 2014 | GE Microwave Ovens
Display window dim
I would open it up and look at the connections to see if any can be replaced. Look for any darkened or burned looking connectors related to the display panel. Hopefully you won't need to replace the display panel circuit board but if you do. I would look for the cheapest replacement starting with ebay parts, and search engines for that specific part. Sometimes there are microwaves of different models with the same parts too!
Nov 07, 2013 | Maytag MMV4205 Microwave Oven
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
Saisho microwave display dim
22ohm resistor on control panel or diode in rectifier short Re: Jeff
Apr 12, 2012 | Microwave Ovens
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
410 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
