Question about Ovens
My GE Profile JSP56 says LOC when I press bake on the touch pad. as a matter of fact it says it when I press sel-clean,surface warmer, broil and convection pads. It doen't do it when I press the clear/off pad.
  • jairosolano May 25, 2011
    I forgot to mention that I had already tried pressing 9 and 0 at the same time. What I neglected to mention is that the display does not show the LOC display until I press bake, broil, self-clean, surface wormer, broil and convection pads. the LOC display shows up even after I press and hold the 9 and the 0 for more than 5 seconds as the manual states. Per the instruction in the manual, I also tried shutting the range off by cutting all power off, but it still stays the same.
    Again, the only pad that is enabled by pressing 9 and 0 is the clear/off pad.
  • Ovens Master
  • 19,396 Answers
Hi.
The oven is in lock mode and several functions are disabled.
To unlock the touch control:
Touch the 9 and 0 touch pads at the same time for 3 seconds until the control beeps twice, and LOC will be removed from the display.
Here an user manual for your range.
Regards.
Ginko
Posted on May 25, 2011
  • Ginko
    Ginko May 25, 2011
    The oven is stuck in lock mode.
    Be sure that you held 9 and 0 down enough time (it should be 5 secs. make ten, just in case).
    1)Press 9 and 0 , and then the clear/off pad.
    2) Disconnect power again and hold 9 and 0 while reconnecting.
    3) 2) Disconnect power again and hold clear/off while reconnecting.
    4) Leave power off (with circuit breaker down) overnight (better 48 hours, that will clear ERC memory).
    If all that does not work, even with oven powered down for two days, then either the control pad is defective or the oven electronic control is defective.
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
The loc on light comes on when i push any button on my stove i do not know how to get it off
The LOC light indicates the front panel lock is on. This keeps you from starting the oven when cleaning the panel; it also keeps children from turning on the oven. To disable the lock, press and hold Bake and Broil Hi/Lo together for 2+ seconds until SF appears on the display. Then press Self Clean. Then press Start to exit the Special Functions menu.
GE appliance manuals are available from their site. Go to http://www.geappliances.com/service_and_support/literature/ and enter the model number of the appliance. Then click Search.
I hope this helps.
Jun 26, 2011 | GE Profile JTP18 Electric Single Oven
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Clock Display
Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
Oct 08, 2006 | GE Profile JT912 Electric Single Oven
Ovens Logo
154 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
