Question about Soundstream BX 20Z Digital Bass Driver with Dashmount Remote Control for Bass Level & PFM Subsonic Filter
My problem is when I turn my car on my epicenter start making noises idk if its they way I connecte or something else if you can please help me that be good. Other thing is do I have to install something to the plug that has the brige
  • 670 Answers
What kind of sound. and is it grounded properly?
Posted on May 25, 2011
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
My gibson gas range making strange noise
Confusing, sounds like your describing a stove but is listed under musical instruments? Does you musical stove have a timer?
Mar 05, 2013 | Music
Mackie 402 turning itself off help please!
You should return it, that's what the warranty is for. Don't even think about trying to sort it yourself
Nov 25, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
When I connect the Mackie 1642-vlz3 from the "direct outs" to the line level inputs of the D3200 there is noise/hum (except for channel 1). There is no noise/hum in the XLR inputs. I have two...
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Jun 01, 2011 | Korg D3200 Digital Studio
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
Static and noise from right side speaker?
interfearence from something in house
May 01, 2010 | Yamaha Portable Keyboard
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Lowrey catillion organ with loud static noise
Try posting on the organforum.com.
It sounds like the power amp has a problem. Probably filter capacitors have gone bad.
Oct 24, 2009 | Music
Soundstream BX 20Z Digital Bass Driver with Dashmount Remote Control for Bass Level & PFM Subsonic Filter Logo
137 people viewed this question
Top Soundstream Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Soundstream Music Expert? Answer questions, earn points and help others
