Question about Car Audio & Video
How to thread needle & bobber on phoenix gloria sewing machine
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
  • 323 Answers
SOURCE: consew 230 sewing machine...will not pick up bobber thread
needle should be 16x257 Industrial machine needle with no flat side.
It does have a long groove on one side and a scallop just above the eye of the needle on the other side. On this machine the needle is inserted so that the long groove goes to the left and it threads left to right.
The thread breakage may be caused by a rough place on the hook. You need to turn the machine on it's back and look and feel all the way around the hook assembly. If you find a rough spot it can be removed with an emery stick. If it's not a rough spot, then the machine is probably out of time.
sewman7
Posted on Mar 20, 2009
Mongo32
  • 111 Answers
SOURCE: I have an old Singer
your machine threads from front to back. make sure the flat side of the needle is facing towards the back of the machine...
Posted on May 29, 2009
SOURCE: I have a morse sewing machine model 4300
Check out this web page for instructions:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Morse_Sewing_Machine_Threading/Morse_4300_threading_Diagram.htm
Posted on Sep 12, 2009
  • 1126 Answers
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Posted on Sep 17, 2009
How to thread a bobber model SE 200JjoAnnSewEssential sewing Machine
The thread will now go downward on the left side of the take-up lever.
  1. Locate and thread any thread guides, leading down to the sewing machine needle.
  2. Thread the sewing machine needle. Hold the thread with your left hand and turn the hand wheel.
  3. Watch for any thread to flap around.
Step-by-Step Guide to Threading a Sewing Machine - The Spruce.
or go to this link. How to thread bobbin Essential sewing Machine Google Search
Oct 26, 2017 | Sewing Machines
Thread is bunching up and it locks. Now needle wont pick up bobbin thread.
if thread is locking up on tension post then its set too tight or is not threaded correctly , this can cause lower thread to miss too having top thread too tight , also ck for a bent needle this is another cause of missing lower thread
Jan 19, 2016 | Sewing Machines
When sewing the bobber thread bunches up underneath, and breaks off. I have tried djusting the bobber tension screw, and upper needle tension to no avail. How often should I oil this machine?
1. Your bobbin should have one drop of oil on the race (little area that the bobbin rides on) around two bobbins that you have emptied.
2. The top tension is way too loose. When you put the pressure foot down pull the thread (top) to see if there is tension. Start at four is a rule of thumb.
3. I have included some rules to follow when you are setting tension.
May 08, 2015 | Sewing Machines
Why does the needle thread in my machine keep breaking? I have retreaded the machine and the bobber and it still keeps breaking
make sure it is on wire tension spring through first loop this affects how the machine pulls thread.
Oct 06, 2014 | Janome Sewing Machines
My bobber won't thread after my thread got stuck while I was sewing. Now it sounds as though my needle is hitting something. HELP!
your machine is out of time.if you are handy you can reset the timing between the upper and lower shafts if not take it to the a local shop.
Jun 26, 2010 | Singer Confidence 7467 Mechanical Sewing...
The needle doesn't pick up the bobbin thread
check the following if the thread swiped properly if the needle is correct if the end turns grabber whether the shuttle is set correctly...
Dec 10, 2009 | Janome Sewing Machines
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
Consew 230 sewing machine...will not pick up bobber thread
sewman7
Mar 16, 2009 | Sewing Machines
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
