Question about Skil 1810 Router
Need to change collet that broke - Skil 1810 Router
    Problem Solver:
  • 5 Answers
The collet is simple to replace - it will pull out if you unscrew one of the large bolts enough. Keep unscrewing the bolt that holds in your bits, and the collet will fall off in your hand. 1/4" or 1/2" replacements are easy to find on eBay or any Skil dealer.
Posted on May 26, 2011
I have dremel 4200 ezchange bit broke inside collet how do i take collet out
remove the collet nut
use pliers or the like and pull the collet from the shaft jaws
remove the broken bit
put the collet back in the jaws and refit the nut
Oct 22, 2016 | Dremel Tools & Hardware - Others
How do I change a router bit on a craftsman router model number 315.174700
lock the collet by turning the on-off switch to off, push the button under the on-off switch to lock the collet then use the supplied wrench to loosen the collet.
Jan 19, 2013 | Craftsman 315.174710 Routers
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
Mar 14, 2011 | Craftsman Single Speed Rotary Tool
How do you change the collets on the Hitachi m12v2?
Matt, Remove the collet nut completely. The collet should come right out of the end of the motor shaft. Put the other collet in it's place and replace the same nut. I assume you are switching between 1/2 inch and 1/4 inch tools.
Aug 23, 2010 | Hitachi M12V2 3Router
Can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Jul 31, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Apr 28, 2009 | Freud FT1702VCEK Router
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Skil 1810 Router Logo
145 people viewed this question
Top Skil Tools & Hardware - Others Experts
ray gallant
richie46
Are you a Skil Tool and Hardware - Other Expert? Answer questions, earn points and help others
