Question about Atd Tools ATD 701 Infrared Laser Thermometer
My laser temp gun is reading about 40degrees to high. i need to know how to fix it. it is a atd-701
2 Suggested Answers
  • 25 Answers
SOURCE: heating element atd-3737
You can purchase the parts from an online tool parts web site. Or you may wish to go to the Milwaukee tool website. They have a listing of local service centers that may have the part.
Posted on Apr 18, 2009
2012 Chevy Captiva reads -40degrees and the heater/ac stopped working. Help!!
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 21, 2017 | Chevrolet Captiva Cars & Trucks
How to check transmission temp sender on 1992 w350 dodge
How to check the Transmission Fluid Temperature Sensor. There is a reason for it. The sensor can skew ,a skewed sensor will mean either the computer thinks that the fluid is either too cold and thick for shifting or the computer will want to go into hot mode. Hot mode means no OD. Overdrive. Overdrive means no mechanical coupling.
Use an infra temp gun. There are two windows to a typical gun. the top window is the laser. It gives you something to point with. The bottom larger window is the infra red. This is what actually takes the temperature. Temp guns are getting cheap.
Place the gun on a hot transmission cooler line and compare the reading to the gauge.
May 16, 2014 | 1992 Dodge Dakota
Low temp on iat reading and my 94 chevy dont have one
Pretty sure it would have an IAT sensor, else your scanner would not have been able to show that. Double check for it-it may be mounted right close to the throttle position sensor,. or the idle air control, somewhere in the intake manifold. Your symptoms of running rich are the classic case of a bad IAT, or a bad Coolant Temp. Sensor. But the scanner said iat, so I would believe that. Do you know for a fact it has no intake air temp. sensor?
Mar 24, 2013 | Cars & Trucks
2002 Chev. Traiblazer- heat guage jumps from low value to high values almost instantaneously . The dealer has replaced the water pump and the clutch fan but the problem persists. Sometimes there is no...
Is the engine actually over heating or just the gauge giving incorrect readings?? The stepper motor in the console's temp gauge could be defective. Have someone with a laser heat gun check the temp of the engine around the thermostat to find the correct temp.
Jul 07, 2011 | 2002 Chevrolet TrailBlazer
How to readR134A ac manifold gauges
The blue gauge is the low side. It should read between 30 to 60 PSI depending on temprature. The red is the high side, and should read roughly 3 times the outside temp. Good Luck
Jun 22, 2009 | Atd Tools R134a Economy Brass Manifold...
Heating element atd-3737
Apr 09, 2009 | Atd Tools Dual Temperature Heat Gun
Laser engrave a gun barrel
this is highly UN-Recommended.
is the barrel is too thin or built poorly you can actually cut through and ruin it.
if you want to paint it the i would use Krylon spray paint
Oct 30, 2008 | Laser Automatic Airsoft Rifle Gun with +...
Atd Tools ATD 701 Infrared Laser Thermometer Logo
Top Atd Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Atd Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
