Question about Lexmark X1270 All-In-One InkJet Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
You need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
Posted on May 25, 2011
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Epson workforce 840 printer gets paper jams. Cause and fix?
make sure that at the point where you add the paper for printing that you have the scale for the weight of paper in use
there is a small adjuster there
Sep 07, 2012 | Epson Workforce 840 AllInOne InkJet...
Won't print. Alarm says it's out of paper, but that is not the case.
Hi
Turn it off and on.
Check through the paper paths and clear any paper jam.
Try disconnecting the printer.
Leave it for like 2 hours and then connect it again.
Feb 26, 2012 | Brother HL 1240 Printer
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
The photo paper keeps jamming won't even print a picture
If it is keep jamming, then there has to be a small piece of paper that you can't see it stuck, re clean and check each rollers, out good.
Jun 06, 2011 | HP Photosmart D7460 Printer
Lexmark X1270 All-In-One InkJet Printer Logo
245 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
