Program cannot be executed due to configuration program setting problem
Service fails to start
follow this
http://www.pcadvisor.co.uk/how-to/software/3233256/how-to-uninstall-troublesome-software/
Oct 24, 2014 | Computers & Internet
Norton virus protection wont allow my browser access internet
Test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
If necessary, later, uninstall the Norton Antivirus completely and reinstall it (please don't forget to download the apps and write down your serial number before you uninstall the Norton Antivirus)
Mar 04, 2014 | Dell Computers & Internet
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
I get the following error as soon as i start casino.exe. The application failed to initialize properly (0xc0000005). click ok to terminate the application. please help me. i like konami casino game...
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention.
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Mar 03, 2011 | Konami Casino Inc. for Windows
My computer will say ''not responding''.
It can happen when the computer is busy executing other programs or the CPU usage is more due to multiple application running at the same time. The best way to resolve this issue is Upgrade the memory on your system. You can also try to disable the startup applications from system configuration.
Press the Windows key and letter "R" on your keyboard
It will open the run windows
Type "msconfig"
Click ok
In the system configuration window select the Starup tab
Click on disable all
Click apply
Click OK or Close
Restart the computer
Jul 19, 2010 | Gateway GT5220 PC Desktop
Office2010 Error Message: setup cannot find setup.exe Browse to a valid installation source andthen click ok.
i solved my problem pointing the browser to the folder c:\documents and settings\(you name)\local configuration\temp. The installation program put a copy of yours main files there, so... bingo! The installation was executed with none more surprises.
Jun 30, 2010 | Microsoft Office Professional 2007 Full...
Unsupported 16-bit application
You could try to run in compatibility mode by right clicking the program executable file and choosing properties, once that comes up look for a tab that says compatibility.
You may have to try different settings to get it to work. Win95 or 98 mode should. The display settings may help as well.
Jul 07, 2009 | Dk Multimedia My First Amazing World...
Installed Norton Personal Firewall and now can't access the Net
1 Start Norton Internet Security.
In the Internet pane, click Settings.
Under Smart Firewall, click Configure next to Program Control.
On the Program Rules window, in the Program column, scroll through the list until you find the executable file for the program that you are unable to use.
For example, if you are unable to use Yahoo! Messenger, scroll through the list until you find the entry for Yahoo! Messenger. The rule for Yahoo! Messenger will be listed like:
Yahoo! Messenger
C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
5
Do one of the following:
  • If you find the entry for the executable file of the program, change the Access to Allow and go to line 15.
  • If you are unable to find the entry for the executable file, click Add and go to line 6.
6
Select the executable file that you need to configure and click Open.
7
Click Manually configure Internet access (Recommended) from the drop-down list and then click OK.
8
Click Allow or Block or Monitor depending on the rule that you want to create, and then click Next.
9
Specify the direction of traffic that you want to apply to this rule, and then click Next.
10
Specify what computer or computers are affected by this rule.
  • If you choose the default setting of "Any computer," click Next.
  • If you want to limit this rule to specific computers, select the "Only computers and sites listed below" option, click Add, and enter the information for the method that you chose (IP address, IP address range, or network address). Click OK, and then click Next.
11
Specify what protocol and ports to apply this rule to. Select the protocol that you want from the list.
  • To apply this rule to all ports (default option), select "All types of communication (all ports, local and remote)," and click Next.
  • To select specific ports to apply this rule to, select "Only the types of communication or ports listed below," click Add, and select the method by which you wish to specify your port or port list. Enter the port or port list for the method that you chose. Follow the on-screen prompts for proper formatting of your lists. Specify whether the ports entered in the prior step are local or remote by selecting the appropriate check box under Locality. Click OK and then click Next.
12
Click Next.
13
Specify a text description for this rule, and then click Next.
14
Review the information about the rule. If it is correct click Finish, and then click OK.
If it is incorrect, use the Back button to go back to a previous step and make changes.
15
Click OK.
16
Click OK.
17
Try to use the program.
Apr 14, 2009 | Symantec Norton Internet Security 2009
Installation samsung 4300 printer in ubuntu 8.10LTX
did you checked port settings on linux control panel and printer settings ?
Mar 08, 2009 | Samsung SCX-4300 Monochrome Laser...
Retreive the setting after ROM Update
It is not recomandable that you do that. After a ROM update the registry configuration is changed, the hexazecimal SEEM components (interface between a flash ROM and the firmware) have different offset values. Altrought there may be ways to restore programs and settings, there will be bugs that will occur. They can vary from simple program errors to wide system crash. I don't recomand such interventions. I've tested some of those programs for PDA's, windows enabled phones, or things such that, but with no real and trouble free results. Many claim that they can do this, in some way the restore process will actually work, but in future .. there will be problems. Please post back for further informations, or if you really want to restore a part of your old backup configuration.
Mar 13, 2007 | i-mate SP5m Smartphone
129 people viewed this question
k24674
