Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Hi .. I have a dream maker spa and it doesn't cut out when the desired temp is reached i have to unplug it, could this be caused by the thermostat if one is fitted and if so can it be replaced thank you Martin
    Top Expert:
  • Dream Maker ... Master
  • 7,905 Answers
Open front power box cover inside cover has schematic or look on board for temp sensor
Posted on Nov 30, 2017
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12761 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
  • 366 Answers
SOURCE: spa won't heat
you need to have the heater tested, there should be about 10 ohms of resistance when testing across the heater leads. MAKE SURE POWER IS OFF, and disconnect the wires at the posts then test for resistance.
If the multimeter reads an open, the heater is bad. Also make sure that you actually get 240 volts across the heater leads when the system is on.
You should have a spa technician test it if you are not comfortable working with electronics.
Posted on Apr 08, 2010
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
What is Ec code on disply mean dreammaker spa
check recirculation pump and heater element if ok temp sensor
Mar 29, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker spa at temp outside 40 is heating water till only 80 dont know what to do.
This is common when your Heater element is bad.
The friction of the water moving through the pump typically will raise the water to around 80.
Jan 17, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Why won't my dream maker spa heat up past 95
bad temp sensor or recirculation pump overheating and turning off
Jan 16, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Do I have to wait until the temp reaches 100 before I use?
You can get in as soon as you are comfortable in the water. I hope the helps.
Sep 25, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
SN ?Non Functional High Temp Sensor? error message
unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
Sep 07, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
167 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Craig Butler
Craig Butler
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
