Question about Canon ImageClass D660 Copier
USING OFFICE DEPOT PAPER 20 POUND PAPER KEEPS JAMMING
2 Suggested Answers
  • 25 Answers
SOURCE: paper keeps jamming in the paper drawer 1 and the
It sounds like you have something interferring with the paper path... Look for any small pieces of paper in the paper path, staples, paper clips etc...
If you can't find any then a service call will be the order of the day!
All the best! If I can help further please contact me : johno@execs.com
Posted on Oct 26, 2009
Paper keeps jamming in my fs2100 kyocera
One possibility regarding paper jamming is the weight of the paper you're using. For example some printers have difficulty feeding 20 lb. paper. I suggest that you first try loading your printer with a lighter weight paper, starting with 12 lb. paper. If that works, then move up to 16 lb. paper. If that fails, then consider cleaning the rubber rollers that control the paper feed.
Nov 02, 2017 | Kyocera Office Equipment & Supplies
Paper keeps jamming
If you are sure there is no more paper stuck try taking an air can to it. You can buy one for a few bucks at staples or Office Depot. For other tips on printing issues click the link below:
https://youtu.be/Zq4MPit1xK4
Apr 04, 2016 | NA Canon PIXMA MG3220 Wireless Photo...
What is the maximum temperature for 20lb Office Depot copy print paper?
The answer to your question is on the office depot website and it catches fire at 450 degrees F. So your answer is no it cannot accept 467 degrees.
Jan 31, 2016 | OKI Office Equipment & Supplies
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
We have a Ricoh Aficio MP c5000 and I'm trying to duplex copy in color and it keeps jamming right at (what I assume is) the fuser. I can copy in black and white duplex but not color. It's almost like it...
Fuser could be wearing. copying in color creates a thicker layer of toner on the paper which in turn creates more friction within the fuser. Make sure the copier is set to thick paper if in fact you are using thicker than 20 pound paper.
Jan 08, 2010 | Ricoh Office Equipment & Supplies
My printer will not feed the paper from the tray.
Have you told the printer what type of paper you are using? If,for example, you were using a heavy weight paper, like a 67 bond paper, and now you want to use a regular 20 pound paper, but have not told the printer about the change in paper weight, then the printer will not feed your paper properly. It is expecting to have to move 67 pound paper through the rollers which move the paper, but is encountering a 20 pound paper. That difference in paper weight will cause your printer to spin uselessly, trying to move a very light paper into the mechanism.
Try to set the paper properties to match the weight of the paper you are actually using, such that the paper and the mechanism, are equal and see if that makes a difference.
Dec 06, 2009 | Samsung CLP 300 Laser Printer
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Right out of the box the printer has jammed every time. I can't even print a test page without it jamming immediately.
Check the requirements for paper..that is usually the problem if it right out of the box. If you look on the side of a **** of paper you will see "20 pound" or "30 pound". The 30 pound is the stiffer paper and easier for printers to pass thru. Of course it cost more too..if paper change does not do it or if you are using correct paper, then I feel since you just bought it you should bring it back. There is really no "fix" for paper jams on a new printer, ie. worn down rollers. Hope this helps.
Pls rate this solution.
Apr 12, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
HP DeskJet 820Cse printer problem
You could try cleaning the rollers with some soap and water. Make sure the power is off first.
Jun 27, 2008 | HP DeskJet 820Cse Printer
Canon ImageClass D660 Copier Logo
23 people viewed this question
old marine
old marine
