I have a spirit soundcraft powerstation 600 powered mixer, i have just purchesed a pair of mackie 450 powered speakers, is there a buy pass out put on the mixer, basically , is there a way i can run the speakers through this desk........thank you
2 Suggested Answers
  • 8 Answers
SOURCE: Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Posted on Aug 10, 2009
Can I connect a Soundcraft Efx12 to a speaker without using an amplifier?
Yes, but it could be pointless.
Headphones are just small speakers so it is usually possible to drive a small pair of "computer/iPod" type speakers from the headphone output.
True balanced outputs should have a fair amount of drive so try connecting a speaker between pins 2 and 3. The higher the impedance of the speakers the better.
Ultimately, the results will be very quiet and the cost of a small amp or powered speakers for low level use is quite reasonable.
Apr 24, 2014 | Soundcraft Efx12 Mixer 12 Channel Mixer...
Why is there no output from one of the speaker jacks?
You seem to have answered your own question but it is possible that the speaker jack is defective
Jan 22, 2013 | Soundcraft Gigrac 600 Powered Mixer
My Mackie 450 turns itself off why
Be aware that TIMED TURNOFF button at the back of the speaker is off otherwise every time sound level is low the speaker can go off by itself.
Dec 16, 2012 | Mackie SRM-450 System
Where can i buy parts for my mackie srm 450 powered speakers
This speaker has a very commercial not-hard-to-find electronics, so you can try Mouser, newark electronics, D'Albani corporation, even Radio Shack, hope this helps.
Sep 27, 2011 | Mackie SRM-450 System
I have a pair of mackie 450 v2 and a pro fx 8 mixer . where do i set the master volume/gain on the back of the speakers? i have followed the instructions from the manuals and seem to be ok but the meter...
hi, you do the right thing, usually the manual is not always right, the settings defend only on sound system set up, so if you have a good amplifier u will get the good sounds of you speakers. thanks
Apr 29, 2011 | Mackie SRM-450 System
Dont know how to hook up srm1801
Go from the main outs on your mixer to the input on the 1801. With an XLR, connect the 'high pass' output on the 1801 to the input on the 450 on top of it.
Jan 09, 2011 | Mackie SRM-450 System
How do I connect a Bose 802 speaker controller to my Spirit 600 powerstation
If you look in the manual at the "hookups" page 1, connect the controller as if it was an EQ. This will insert the controller between the mixer and the amplifier.
Dan
Aug 29, 2010 | Audio Players & Recorders
We use a mackie dfx 12 mixer and 2 mackie srm450 active speakers for a band situation the mics are sure sm58s we have to keep the levels of each cannel mixers quite high what are we doing wrong
Does the VU-meter (green/yellow/red strips of LEDs) on the mixer go all the way to the top when you adjust gain and slider level?
If yes, try boosting up the active speakers by adjusting the small volume button at the back of the speakers.
Also, make sure the equalizer (on the mixer) is set at 0 (the middle) for every slider (And not at -12). The 'voice cancellation' and 'break swich' should also both be unpressed.
Dec 13, 2009 | Mackie SRM-450 System
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
173 people viewed this question
 Grubhead
Grubhead
