Compresor and condenser fan start but kick out in a few mins..
    Genius:
  • 1,015 Answers
The first thing I would check is the system pressure while the unit is running and see if it may be going out on high or low pressure. Often if you are very low on refridgerant thelow pressure line will start to frost. Check condensor coils and clean if neede.Make sure that your return air filter is clean, if not replace it. If you can get access to A-coil then check it and clean as needed. If you have not done so try turning your thermostat up a few degrees higher then you would normally. Hope this helps you. Thanks
Posted on May 25, 2011
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
Not cooling, compressor and condensor coil fan not running.
It sounds like you may have bad starting components on your compressor. I would check your condenser fan motor for 120v. Or try to put a small box fan behind the ref blowing directly on the compressor to aid in cooling it. If the compressor kicks in then you know the problem is with your condenser fan motor and not your compressor. If the start components are bad you will usually hear a clicking noise from the compressor every 10-15 mins or so.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
The condenser fan runs, 30 second later the compresor kicks in then 20 seconds later the compressor turns off while the condenser fan is still running
You have either a bad overload/relay or a bad compressor . Remove the o/r from the compressor and make sure there is continuity between all 3 terminals . Also check from the terminals to a copper line to make sure there is no continuity . If ok , then replace the o/r and check the amps from a wire to the compressor . If high amps ( 2.7 or higher ) then compressor may not have long left .
Jul 16, 2009 | Refrigerators
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
