Question about Micro Electronics WinBook Si Notebook
Winbook xl battery placement in the motherboard
When i start the computer it asks for a password, i never had one. what can i do? i get in to the cmos and wants a password
Bios password reset cmos
Ok so reset the Bios Password? Ok well open the computer up and remove the Cmos Battery from the motherboard ....make sure to have computer unplugged and use static protection also there maybe a jumper setting to clear the cmos so check for this jumper usually in the same area as the battery after removing the battery or using the jumper to clear the cmos all you got to do is return the battery and or jumper to the original placement and your done ... just plug the computer back in and its reset.... Good luck
Oct 13, 2013 | Dell Latitude D830 Intel Core 2 Duo T7250...
It is a winbook xl when i power it on the battery light turns on not any other lights i dont see any thing on the screen or hear the harddrive or any thing not even a beep i need help the laptop is about...
Without seeing it, I'd guess the power unit might have failed, or it could be the motherboard. Modern computers have a system management controller you can try resetting, but on a 15 year old laptop I don't know what the equivalent would be, if it even exists. If it's the motherboard chances are it'll be cheaper to buy a new computer.
Jul 28, 2013 | Computers & Internet
Acer aspire one kav60 restore asking for a password.
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
if still no luck
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten hope it helps
Apr 27, 2012 | Acer Aspire Computers & Internet
Intel Hp c.p.u. asking password .we do not use password to open our p.c.then why our p.c. ask for password ?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 03, 2011 | HP Compaq Motherboard
Clear password
go into the bois and set the password off, restat the pc press delete or f2 yust read what they ask you, what happend is you cmos battery went low so it reseted the default cmos settings, replace the battery if you have to, it will work
Oct 08, 2009 | Intel Motherboard
I have a WinBook XL Laptop that will not Power up,start up, switch on.
Check your power adapter if it is still working. Try taking out the battery and plugin the power adapter and see if its gonna turn on.
Jun 02, 2009 | Winbook Corporation PowerSpec MCE 410 PC...
Laptop CMOS battery
This is for Winbook WinBest 233MMX may be good for other Winbooks
Had trouble booting then just quit booting altogether...
For a quick fix that won't require soldering....
Replace the cmos battery2.gif. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard by sliding the KB toward you and lift the top up and slide out, Remove KB ribbon cable2.gif from connector by pulling on the plastic tab, remove the 4pin KB power connector. Then remove bottom screws and separate the case.
Locate the 3V battery, Pry the top tab of the 3v battery off the welded ends with a small needlenose, Pry the battery off the mini board, bend battery tabs so the new non-tabbed battery will be squeezing the new battery for contact, + is up!, add a piece of electrical tape to secure it from sliding. Replace bottom case and screws and then re-attach keyboard2.gif ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot. Set your time. You must set the boot sequence to C:. It will then auto boot to C: WALLA! WIN98!
Mar 18, 2009 | Micro Electronics WinBook J1 Notebook
Acer aspire 5050 asking for a password upon start up
If it is asking for a password upon startup then someone put a password on your CMOS. Unfortunately, unless you can find out what the password is, then the only way to clear it is to remove the battery in your motherboard. The battery is what keeps the information in CMOS when the computer is turned off.
Dec 21, 2008 | Acer Aspire 5050 Notebook
PASSWORD PROBLEMS
Hi, To access or enter motherboard BIOS settings, on powerup either F2 or Del. If you just want to remove the password in your Dell Optiplex > The BIOS password may be cleared by removing the password jumper (PSWD) on the motherboard. This will also clear all CMOS settings: Open your casing, on your motherboard. find the CMOS password reset jumper (3-pin) on the motherboard; Remove the jumper from pins 1 and 2 and put it on pins 2 and 3 for about 5 seconds. Replace back the jumper on pins 1 and 2. Hope this be of help/idea. Good luck and kind regards.
Aug 27, 2007 | Dell OptiPlex GX270 PC Desktop
Micro Electronics WinBook Si Notebook Logo
696 people viewed this question
Top Micro Electronics Computers & Internet Experts
Ekse
Alun Cox
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
