I have been trying to connect my Wii to my Linksys wireless in my home and every time I try, I get the error code of 51330 with a mention of being unable to connect to the internet. What can I do to fix this issue? Thanks
    Scholar:
  • 69 Answers
A. Do you have the SSID for your Linksys router as just "linksys"? That name is so common that someone nearby might have set up a new router and left it the same name as well... and your Wii is trying to connect to THEIR "linksys" instead of yours. Try changing the name broadcast by your router to something else, then try connecting using that new name.
B. Be sure you are typing in the WEP or WPA passphrase correctly, it is SO easy to mess up one simple letter in the code and nothing will work. I've gotten dozens of service calls for iPods and games where the customer said their code didn't work, but worked for me when I got there. I know, it's frustrating, just be SURE you have the code 100% correct.
Other reading material from Nintendo is below:
Wii error code 51330 It is unlikely that your Wii console needs any type of repair, as according to the Nintendo Error Code Lookup, the 51330 error code is "usually indicates a problem relating to wireless security."
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  8. If you are still receiving this error code, please click here for assistance.
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one of the service representatives will do some over the phone troubleshooting to determine exactly what is causing this and then talk you through any needed steps to correct it.
Posted on May 25, 2011
Trying to connect to the internet through Wii but getting error messgae # 51330
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings.
WEP AND WPA Security keys are case sensitive.
Aug 28, 2011 | Computers & Internet
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
I tri to connect internet error code 51330
Error code 51330 is trying to tell you that the Wii Wireless Adapter cannot connect to your wireless router. The most likely reason for this error is that the password you entered is not typed correctly, or that you forgot to type one in at all. Remember that security keys are always case sensitive.
Jul 01, 2011 | Nintendo Wii Console
We have a error code 51330 ,while trying to connect to netflix
The 51330 error code is in reference to a wireless router security issue.
Solution: Reset* the router that your Wii is connected to back to it's default settings.
The router's default settings will put an end to the 51330 router security error.
*some routers have a 'RESET' button located on the outer casing, other routers can be reset using the software that came with your router
Mar 06, 2011 | Nintendo Wii Console
When trying to connect to internet , when we enter our password we get error code 51330. What does this mean
Dec 29, 2010 | Nintendo Wii Console
I have problems connectiong to wii
Restart the router and reconnect all over again. If problem persist please see your service provider.
Cheers
Apr 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Cannot get connected to wireless router. Error
You have to either get y our wii closer to it or try everal times.If there are any objects in the way of the routers remove them and if that doesn't work im out of ideas
Mar 06, 2010 | Nintendo Wii Console
Error code 51330
That's usually a problem related to wireless security. You'll want to try to make sure your computers can connect to the wireless--or see if it's working or not.
If everything is good. Make sure the password you have on your Wii to connect your console to the wifi is good.
That should work... if not, reset your wifi settings and try again!
Feb 08, 2010 | Nintendo Wii Console
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
