Question about Relic Wet Multifunction ZR15385 Watch
Relic Wet ring around the crystal
This watch has a ring around the outside of the crystal with minutes printed on it: 10-20-30-40-50-60. The 60 does not line up with the 12, and I can't figure out how to take it apart and make it align properly. The 60 is closer to the 11. Now maybe it's supposed to be that way, but it sure looks funny. The people at JC Penney couldn't figure it out, either, but they at least got the links added.
  • Relic Master
  • 13,434 Answers
This may be silly but, in some watches you can actually rotate the outside ring. try rotateing it does it move at all? a local watch service should be able to adjust it if its locked in somehow, if you pull the plug out would it move then?
Posted on Aug 16, 2008
SOURCE:
Where to find batteries for relic watches?
Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
May 26, 2014 | Relic Wet ZR11672 Wrist Watch for Women
I have a Relic watch with crystals around it, Two of the crystals have fallen out. How might I get these replaced?
If those are rhinestones it will lose it's color if you were to replace them. If it's Austrian Crystals or better you can buy them single on ebay and have a jewelry repair person re-attach them for you.
Feb 10, 2013 | Relic Watches
I have an Relic Fossil Brand Watch and I took the back Cover Off and I cant Get the **** thing back on.. how do you put the back of it back on?...
try to press on as much around as you can then whatever area is still showing a gap gently push it on a corner of a desk ( be careful of crystal), but it sounds like you may not be able to get it back on. Watches need even pressure all the way around to put the backs back on this is done with a watch press. The watch press cups the crystal and applies even pressure to snap the back on. It sounds like you will have to go to your local jeweler. We use the watch press to put on about 75 percent of our backs! Fossil is especially known for difficult backs and crystals that easily break! although they are a nice looking watch!! hope this helps!!
Sep 20, 2011 | Watches
Where can I purchase a crystal for a Relic Wet watch. Could you tell me the price.
Thank you for contacting FixYa.
You can try contacting Relic at this link to see where to send for a replacement:
http://www.relicbrand.com/contact.htm
You can also try a local watchmaker. Depending on the crystal, most can be cut to fit and the price varies depending on the type of crystal, difficulty, etc. Take to a local shop for estimate.
Hope this helps!
Jewel
Oct 08, 2010 | Relic 0504648FA
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
    The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
    Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
    To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
    Aug 26, 2010 | Relic Watches
    The crystal is cracked in my Relic mens wristwatch. Can I order a crystal on-line and replace it myself?
    Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
    Oct 02, 2009 | Relic Multifunction Watch
    Relic doesn't run. TheFossil is missing the bezel.
    There is a little tab next to the battery that should have an arrow pointing to it. You will have to depress the tab with a pin to get either the watch to start, or the eight ball and flames to start flashing, after replacing the battery. If this doesn't work, the watch is probably junk, as the movement has been damaged from the impact that broke the crystal. I have done this exact thing on this type of watch two years ago, which is how I know, except that the flashing image in the background was the chinese characters for love, peace, and happiness. It was also a Fossil Relic. Hope this helps. Bilal Hassan Clarksville, MD
    Jun 03, 2009 | Watches
    Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
    Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
    Sep 03, 2008 | Watches
    Relic Wet Multifunction ZR15385 Watch Logo
    176 people viewed this question
    Top Relic Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Marvin
    Marvin
    Are you a Relic Watch Expert? Answer questions, earn points and help others
