Question about Fisher and Paykel AeroTech Double - OD302M Electric Oven
We have the OD302 model and after self cleaning done fan still works, lights come on but oven does not heat up. Where is the reset mechanism. It has been said that we need a repair man to come and have a look. My husband is techincally savy so can he reset the mechanism??? Please reply to celinecarkner@hotmail.com
You have to get a repair man in to replace the thermostat
Posted on Jan 24, 2013
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: OD302 double oven is very
Hi, all you need to do is replace the thermal fuse which will solve the problem.....
Posted on Mar 15, 2011
After using self cleaning oven temp will not rise above 80?
call your local repairman something melted from the excessive heat of self cleaning
Mar 12, 2016 | Fisher and Paykel AeroTech Double OD302...
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
Whirlpool self cleaning oven will not heat up after cleaning. Lights and fan come on but not the elements. I have 223 volts to oven.it is model number RS696PXE
Hello Ken, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, the scenario you described is exactly how this would manifest
...that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back. (this can also occur during power surges)
You'll need to slide the range/oven out from the cabinet. If you slide the unit away from the wall and unplug it you can check the hi-limit.
Based on the model number you provided it should be a non-reset type hi-limit or push to reset. If non-reset it needs to be replaced.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like either of these...
NON-RESET
PUSH TO RESET
(Not likely...unless model is wrong)
The replacement if necessary are available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Oct 24, 2011 | Ovens
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven wont work after cleaning
I have a single wall oven by fisher paykel I have had the same problem with it not working after the last self cleaning mode.
no fault codes show and the fan and light comes on and blows out cold air. I have reset the power and still it wont heat. broiler is out too. I called the store where purchased and was told they will order a part and come out. This must be an ongoing problem as they did not need to come out and trouble shoot .
I will have to barbeque for a while !
Feb 08, 2007 | Fisher and Paykel AeroTech Double OD302...
Fisher and Paykel AeroTech Double - OD302M Electric Oven Logo
217 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Flipper
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
