Question about Rockford Fosgate Punch P325.1 Car Audio Amplifier
I just hooked up my RF 325.1 Amp to my Sony CDX-M30 deck and a small 10" Alpine Sub in a small box. I ran the wiring according to the install instructions for the Amp, but I am getting a very loud low Hum from the sub. I get bass out of it, but unless it is turned down almost all the way, the hum is over powering. This is in my boat, I ran an independant power cable from the sub to my Positve Battey block and an independant Ground cable from my Negative battery block, The RCA cables are plugged in from the deck to the Amp and the REM Power is connected to the Remote Power on the deck. The 2 speaker wires are connected from the Amp to the Sub. The ony deviation I made from the instructions is the Negative line is much longer than 3 feet, it is about 15'. This is because it is in my boat, and there really wasn't a ground anywhere near the Amp location. I either had to run an independant neg. line to the battery or splice into another ground of unknown length. How do I get rid of this Hum? Thanks Mark
  • 32 Answers
The reason for the 3' min. on your ground cable is that interference is picked up with longer gound cables. Especially if it passes close to any electrical components, e.g. spark plugs, capacitors, anything with electrical current. These signals are amplified within the amp. (because this is what amps do) and distributed to your speakers. you could try a noise filter / noise suppressor but I've never had luck with those. You could also try finding a metal part of the frame (if there are any) and attach your ground to a bolt along that frame and if your more advanced you could create a hole and use a screw to tighten the ground to the frame. Small note to that, boats create a lot of vibration so use a ground screw with a sort of tooth like seration at the head that grips as it tightens (so it won't come lose). If you have an extra battery you may want to attach the amp directly to an independant power source to see if your getting the same hum. A direct short in your electrical system will create the same sounds. A bad ground your electrical system will do this also. You may also want to check you high and low band pass frequencies if applicable. Set them to high and you'll get a hum. I would start there adjusting them down or setting them to the center and adjust accordingly if this stops the hum. I'm running 4200 watts all together and if I adjust to high I get interference just from the force of the amp itself. Good luck. Hate electrical problems on vehicles, too many wires.
Posted on May 25, 2011
  • markkowall May 25, 2011
    Can I make my own Ground by using a large metal screw or bolt and a pair of washers screwed into the fiberglass structure? Does that work?
  • ray0427c May 25, 2011
    No, has to be the metal frame that the battery ground is attached to. If any. Boats are limited when it comes to metal. Have you tried adjusting the low and high Frequency band passes yet. And is it a buzzy / whiny type of sound when motor runs or a power surge type of hum like a transformer.
Installing a Sony CDX-GT09 in a 2002 VW Jetta- power, no sound
definatley amp issue there should be a green wire with a red stripe in your harness, if you take the blue wire with a white stripe from the sony deck and hook it up you should have sound. good luck
Dec 29, 2009 | Car Audio & Video
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
May 15, 2008 | Sony CDX-646 10-Disc CD Changer
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Sony CDX-MP40 won't power up the amp.
Most in-dash stereos have a blue wire in the harness which is used as a "wake up" signal for external amps. Did you connect this? Does it have any voltage on it when the stereo is on?
Mar 03, 2007 | Sony CDX-MP40 CD Player
Rockford Fosgate Punch P325.1 Car Audio Amplifier Logo
190 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
