Question about Electrical Supplies
Onan microlite 4000 KY No spark checked coil and it meets service manual spects Only 2 volts from magneto to coil changed magneto still only 2 volts out of magneto input to magneto from controler A1 is open what am I doing wrong thanks Chris
4 Suggested Answers
nuworldman
  • 11 Answers
SOURCE: onan microlite 4000 generator will run for 2 to
Does it start right back up or does it need to cool off for 10-20 min?
Posted on Sep 06, 2009
  • 6468 Answers
SOURCE: Onan microlite 4000 Model-4KYFA26100B, Will not start not getting a spark, i have changed the coil wire still no spark
check the low oil shut off system
Posted on Aug 30, 2012
  • 16 Answers
SOURCE: By pbarker987 on Jun 02, 2010
Because it wont start does not indicate a control board problem It will start but it will shut down within a few seconds if it was. enail me and i will try to help you with the problem jbogilvie@hotmail.com
Posted on Jul 02, 2010
I have a micro quiet 4000 starts up but surges up and down , could it be just old gas making it run so bad
The reason can be:
  1. Bad or loose ignition (spark plug, magneto, coil cable etc);
  2. Water in the gas;
  3. Dirty fuel strainer;
  4. Not set on level surface;
Jul 10, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
By pbarker987 on Jun 02, 2010 " " I have an onan microquiet 4000 KY. It will not start, fault code on red light indicates (35) control card failure. Before I take it to authorized onan repair is their...
Jun 23, 2010 | Watts Onan Portable Generator - 4000 ,...
The onan generator will not start 4000 KY----looks
If it is clicking it may not be bad, Sight unseen. Your problem is a low battery.
R/
David
Jan 04, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
377 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
