Question about Toro Garden
I have toro z420, front tires are hitting deck and bolt that runs to front Frame that holds deck. Seems to be a clearance issue, no zero turn.
4 Suggested Answers
  • 64 Answers
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Posted on Aug 23, 2009
mowerman1857
  • 389 Answers
SOURCE: tire pressure for toro z420?
Front tires 35 psi (139 kPa)
Rear tires 13 psi (90 kPa)
This information can be found on Page 29 of your Owner's Manual
Posted on Oct 27, 2009
huffman49
  • 235 Answers
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Posted on Apr 14, 2010
Is there any way to bypass the switch that engages the blades on my Husqvarna RZ4219 zero turn mower so that it will start?
get a test light, this will make troubleshooting alot easier. check seat switch,stick,neutral,guard and the power in and out of the key. 6 12V Circuit Tester with 5 ft Lead
Sep 04, 2015 | Husqvarna RZ4219 42" 19.5HP Zero Turn Lawn...
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
We recently bought a second hand Toro Z420 ride on mower but there wasn't any manuals with it can you help as I can't seem to print one from your site even though you say we can?
hi there pauly 46 here
hi peg ed
here is web site to download service manual
http://www.kohlerplus.com/main_frame.asp
enter as guest
select kohler courage single, then scroll down to service manual , then select SM 20-690-01
(replaces tp-2548 a) and download a copy to your hard drive its 6.05 Mb
here is web site for toro manual
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
under manuals , enter 74327 as model , time cutter z420 will come up in a list of 2
see if this will let you print anything
cheers
May 16, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Engine runs, blades turn but mower will not move
Look in front of back tired on frame, not deck, there are. 2 rods, 1 on each side, rods look like a L, it's going through a little eye opening, push it backards, mower should move. If rod is pulled through opening and locked in, mower will not move..its a safety. Feather on mower
Sep 01, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Tire pressure for toro z420?
Oct 24, 2009 | Garden
Garden Logo
47 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
