Question about Electro-Harmonix 12ay7 Tube Microphone Preamp
A big hum of 100 c/s in the output,i need the schematic for repair
  • Electro-Harm... Master
  • 5,603 Answers
You must be on 50Hz power. You don't really need a schematic to repair the unit. Since the hum is twice power line frequency, the likely cause is the electrolytic filter cap for the high voltage has failed. The cap should be obvious in the unit. It will be near rectifier diodes and have a voltage rating above 50 volts. To test, bridge the one in there with another cap observing the correct polarity. If hum changes, replace the original cap.
Posted on May 25, 2011
Hi , Do you have a full schematic for Mackie 32.8 mixer ?
http://www.mackie.com/products/32-8bus/#DOCUMENTS will have an owners manual- it has a block diagram in the last chapter.
Sep 18, 2014 | Music
Mg smokin makes 60 hz hum
Probably the power amp chip has failed with a short to one of the power rails. This will cause hum and ultimately wreck your speaker. Take in for repair.
May 13, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have this problem. my bass amp is blowing fuses SWR workingman4004 the problem is that not only burns but also fuses the 4 output transistors (2sc3264) and a resistance R22, and replace them when I was...
I don't have a exact schematic for your amp, but I can give you some hints and suggestions...
USUALLY when the output transistors fuse there is a problem at least one level back and sometimes two levels. Often the driver transistors also get fried and sometimes one stage farther where the bias is regulated for the final amp transistors. A schematic is imperative to diagnose and repair unless one replaces every part.
Next, to prevent damage when restarting the amp, put a 100 Watt incandescent lamp in series with the hot power into the unit. This acts as a current limiter and auto-resetting fuse. The lamp will come on and limit the current while one troubleshoots the amp to find what is causing the current drain.
This schematic MIGHT be pretty close to your unit:
http://elektrotanya.com/swr_swr2000_power_amp_module_sch.pdf/download.html
I would expect to see Q4 through Q12 destroyed and maybe a few more components. If transistor Q4 opens, goodbye all the transistors! The 1N4004 diodes are PROBABLY big enough to take it, but all the small transistors probably are damaged or degraded... The high value resistors will survive, but the low ohm ones that can draw enough current may be damaged.
Try to analyze what each part of the circuit is for... I think Q13 and Q14 are part of a soft start circuit. This amp is NOT well protected in case of component failure and MANY that fail in the final stages cause catastrophic destruction.
Use my suggestion for the lamp. Often using a Variac to slowly bring up the voltage is handy, but one doesn't only have one available.
Mar 04, 2011 | SWR Music
Laney GH100L amp...weak/distorted output...Output tube plate voltage is 100V higher than the schematic states...any ideas?
That high a voltage MIGHT indicate the output tubes are NOT loading the supply enough. You don't mention the voltages andthe tubes used in the unit. I have a schematic for a AH100 but I don't know if it is close to your unit. That schematic shows four output tubes.
Remember if you put matched tubesas pairs, the pairs need to be on opposite sides of the output transformer.
Feb 16, 2011 | Music
Fender vibrolux. Very (loooud) loud hum/buzz All tubes but the 6l6's removed. History: bought this amp as a repair project. replaced all caps. originaly the amp was quiet but but had very little volume...
Here is the schematic:
http://elektrotanya.com/fender_vibrolux_6g11_schem.pdf/download.html
Check the quality of the DC bias as being free of ripple.across teh 25 mfd/50v cap filtering the bias.
If much ripple there, replace the cap. Also the .05 bypass on the swinger of the intensity control.
This should be an easy fix, but you might need an oscilloscope to diagnose it quickly... or just parallel caps across these to see if it kills the hum.
The main high voltage filter caps are also suspect as well as the bypass of power to the ealier inverter stage a 16mfd/450v
There are lethal voltages in this so use great caution when troubleshooting... the caps hold a nasty charge.
Feb 06, 2011 | Fender Custom Vibrolux Reverb Tube...
I am attempting to repair a Kustom K100A-1 guitar amp. I found one shorted output transistor, an RCA 36892, which crosses with a NTE 130. Do I need to replace all 5 outputs with matched transistors, or can...
I don't have a schematic for this unit, however good design would not demand matched transistors.
If a transistor has shorted, USUALLY mating transistors have been damaged. I am not sure how "5" outputs are configured as usually there is symetry and an even number. If the "5" are all on one side and there are mating trnsistors of another number, then likely there is damage to more components and probably back one stage in the drivers or even farther.
Hint: when re-powering this after repair, put a 100 Watt light bulb in series with the power into the unit to act as a limiting fuse that resets without driving heavy current into the unit causing more damage due to failed parts that were not eliminated in the first reapir.
Jan 06, 2011 | Music
Marshall AVT20X hums and no sound from the input jack (speaker voltage during humming is 13vDC)
Likely one half of the full-wave rectifier has failed. Take in for repair. Sometimes output amp shorts to one power rail causing this. DO NOT continue to operate this until repaired as it will destroy the speaker!!!
Jan 01, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
Loud speaker hum then blows fuse
Hi there. The final output IC (big and black with 15 pins? attached to heat sink) is shorted and needs to be replaced. If you can still see color bands on R63, it should still be good.
Thanks
Paul
Jul 12, 2009 | Music
On power up there is a loud humming even with volume at 0
I would also be inclined to check all the larger electrolytic capacitors in the power circuits as well for AC bleed.
Feb 11, 2009 | Yamaha Electric Guitar
Electro-Harmonix 12ay7 Tube Microphone Preamp Logo
98 people viewed this question
Top Electro-Harmonix Music Experts
Vito Vacirca Jr.
Are you an Electro-Harmonix Music Expert? Answer questions, earn points and help others
