When I load a dvd to play the player makes a few noises but then ejects the dvd
  • 1,056 Answers
A common possible cause to this is there is a mechanical problem inside. Once the device is opened, the DVD section is actually seperate box. It contains all the mechanism and a few electronic circuits. First open the cover which has only a few screws, and while it is opened load a disk in there so you can see what is going on. If it looks like the tray is not going in all the way, You can actually remove the tray, with the tray removed plug it in then press eject. Then insert the tray and this will automatically put it back on track. You may have to do it several times untill it goes in there propely where it wont eject anymore. Good luck.
Posted on May 25, 2011
When trying to play DVD, the DVD shows player is loading with a lot of noise before ejecting DVD? Bauhn TV/DVD from Aldi - has been playing OK and this is now happening with all DVD discs?
The DVD player has failed, due to the low cost of these players seldom are they sent for repair. would recommend a new "OPPO" brand DVD player, they last forever
Dec 08, 2016 | Televison & Video
My DVD player for navigation system keeps ejecting dvd
Does it make this with every DVD or only a certain few? Have you played DVD properly before?
If yes to both, then it's possible there is some debris inside that needs to be cleaned.
If the answer is not yes to both of the above, then let me know to find another solution.
Feb 07, 2014 | Computers & Internet
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
Insignia blu-ray player only plays music cd's. Ejects BD's.
Try to clean the player using a bluray cleaning kit. Dont use the dvd cleaning kit as a few can cause problems. Look at packages and see if they can be used on blu-ray players.
If this does not fix the player call Insignia immediately as the laser can be broke and will be expensive to fix. These players have a one year warrante so you should be covered
Dec 26, 2009 | Insignia NS-BRDVD Blu-Ray Player
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Some normal DVD's will not play--as if not loaded.
try using a lens cleaner.....normally its a lens issue....should work better after cleaning...
May 17, 2009 | Sony SLV-D300P DVD Player/VCR
DVD Stuck in player
There is nothing you can do with this problem unless you are able to repair DVD players, the loading mechanism of any DVD player is very complicated, chances are a small part has broken. Call the dealer and ask for the phone # of the repair center they use, call them for an estimate, don't go through the dealer, they will double the repair bill from the radio shop.
Oct 14, 2008 | 2003 Lincoln Aviator
Cyberhome DVD Player not playing CD
I had a similar problem, and I took the player apart to find that there was a motor that has a snap-in connection to a circuit board and it was just disconnected. It controlled the movement of the reading laser. I could hear it make some noise. I reconnected it and it worked fine. There are quite a few philips head screws to remove to get into the case. It slides off the back. Once inside, it's very simple looking, it is really un-intimidating. You may have 4 more very small screws to remove directly on top of the DVD tray. If you need to take it off to see under the tray that is. I'd like to guess the problem is that the motor that ejects the tray is disconnected.
Mar 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
