Question about Haier Heating & Cooling
Air is not cooling - Haier Heating & Cooling
    Genius:
  • 1,015 Answers
First thing is to check the refridgerant levels and add if needed. If this does not help let me know and I will suggest other options.Thank you.
Posted on May 25, 2011
New thermostat, new radiator, system flush, still not much heat??
You need to 'burp' the system to get air locks out.
  • Burping The Cooling System "How To" - YouTube www.youtube.com/watch?v=BQk9HpuIrmA
    • BY NTHEFASTLANE
    • 4 MIN
    • 199K VIEWS
    • ADDED 2012-08-26
    Video embedded · Buy the items featured in this video! Click here: https://rdy.cr/08fb93 How To Use A Spill Free Funnel to burp your radiator Lisle 24610 Spill-Free Funnel ...
  • How to Burp your car's cooling system - Instructables www.instructables.com/id/How-to-Burp-your-cars-cooling-system Video embedded · Intro: How to Burp your car's cooling system. This instructable will walk you through the simple process of "burping" or getting all of the trapped air out of ...
  • Clearing the Cooling System of Air. 'Burping' the Radiator ... www.youtube.com/watch?v=cRPEqO06O58
    • BY JERRYRIGEVERYTHING
    • 3 MIN
    • 232K VIEWS
    • ADDED 2012-08-13
    Video embedded · Clearing the Cooling System of Air. ... Burping The Cooling System "How To" - Duration: ... How To Bleed The Air Out Of A Cooling System ...
  • Related searches for burping coolant system
  • How to Burp Your Car's Cooling System ' eHow www.ehow.com > Cars > Auto Repair > Do It Yourself Auto Repair How to Burp Your Car's Cooling System. Clearing air from your car's coolant system is a fairly easy task. You need a floor jack, a set of jack stands, a helper and ...
  • Jan 27, 2016 | Cars & Trucks
    Tip
    Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
    The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
    Aug 27, 2014 | Heating & Cooling
    Over heating and sputtering
    kohler engine air cool they will over heat if fuel system lean carburetor clogged out of adjustment causing lean fuel mixture,air cool engine need plenty air to keep cool, make sure air filter clean and make sure cooling fins not clogged with debris make sure shrouds and blower housing are tight so air can circulate. air cooling engines kinda remind you of 1963 corvairs
    Sep 09, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
    Haier esa410ke manual
    my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
    Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
    Cool air coming from the vents in the front but hot air coming from the back. What do I do to stop the hot air so that the room will cool down?
    The hot air is a product of the cooling.... if you stop that then the unit will not cool!!!
    You need to buy an exhaust kit to vent the hot air outside so that it will cool the room.
    Otherwise it is just what is called a spot cooler or in other words you are cool if you sit in front of it, but it actually will make the overall room temp. hotter!!
    heatman101
    Jul 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
    WHAT IS THE MAXIMUM COOL?
    Maximum cool is the highest fan speed and no vent.
    Apr 15, 2011 | Heating & Cooling
    Sunpentown SF-609 Evaporative Air Cooler - no cool air
    Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
    Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
    Heating & Cooling Logo
    24 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Terry Hair
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
