Hauzen sew-hqw111t front load washing machine. When I open the drawer to put in the soap there are three compartments but everything is written in korean. Which compartment is for laundry detergent, fabric softener, etc? Please help
  • 58 Answers
SOURCE: Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
SallyUK
  • 9 Answers
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
Posted on Jun 16, 2009
attiq_rha1
  • 25 Answers
SOURCE: The fabric softener compartment of the detergent
I have had my machine for the past 6 years, I do on average ten loads per week, and it has never failed me. A bit noisy but for the price I could n`t complain. I have just broken the door handle which has cost me a total of #8.50. Not bad for six years hard labour
Posted on Dec 04, 2009
How do i get the soap dispenser unclogged?
Open the soap dispenser drawer and press the green drawer retainer (in the middle compartment) down while pulling the drawer outwards, this will release the catch on the drawer.
Sep 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
    I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
    Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
    I don't have a manual -- where goes the soap?
    Did you try and look up the manual on line? It is available on page 12 it tells you were to load it. It is a pull out in the front of the machine with three compartments.
    Mar 02, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
    Soap powder remains in the soap compartment
    Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
    If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
    If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
    Plz rate this solution.
    thanks.
    Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
    Washing machine drawer
    This video will show you how to keep your soap draw clear and how to service the parts
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    Jul 14, 2008 | Indesit W 123 Front Load Washer
    Opening the top of front load LG washer
    to get your lid of the washer there are 2/3 screws at the back right under the lip of the lid once you have taken the lid of u will see the top of the soap drawer u can sometimes get into these by undoing the clips on either side of the soap drawer if u cant do it that way only other way is to make sure your soap drawer is closed properly and hit it hard at the front it should dislodge more than likely your conditioner drawer
    Aug 15, 2007 | LG WM-2277HW Front Load Washer
    Washing machine problem
    at the back of the conditioner compartment there is a syphon. check the tube of the syphon is clear. put on rinse and at the point the conditioner should be taken, open the drawer and check that there is a jet of water into the conditioner area. if not, there are some holes in the roof of the top of the box. these may be blocked. clear with a hairpin or similiar
    Apr 22, 2007 | GE WSXH208A Front Load Washer
    Washing Machines Logo
    99 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
