Question about Epson Dot Matrix LQ-300+ Printer
The printer leaves whiel lines I read that i need to align the head where is the head? thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Epson Expert
  • 259 Answers
The head is the writer which move in print process
Posted on May 25, 2011
The black cartridge leaves blank lines while printing
This usually really means that you have clogged ink inside the delivery tube for the black ink flow to the inkjets. VERY Hard to repair, but since you still have ink flowing, switch to blk ink printing such as lots of text, and keep printing it out to see if it will clear out the dried ink in the micro tips. You can't change out the printer roller in this unit. I know, that frustrates me too! This may take a bit of time to do!! Also make sure your printer blk is up to date with new computer 'read' tabs, if not it can create read problems in the system. If you refill inks at a store, which of course is cheaper, make sure they also install the reader tab on the ink block.
Hope this helps!
Cheers
Vicki
Mar 04, 2013 | HP Photosmart C8180 InkJet Printer
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Constant mesage to realign ink cartridges. have done it 3 times and message still there . Cant use copier or scanner facility as a result
Replace the cart. if that does nto work you got a bad print head as its not reading correctly if the cart is aligned witch will send a bad signal to the PCM printer control module to align the cart. please try a replacement if that does nto work replace the print head at that point.
thanks and please do leave postive feedback for your free aolution today.
Nov 17, 2009 | HP PSC 2210 All-In-One InkJet Printer
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
Aligning Print Head Alignment
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Oct 04, 2008 | Canon BubbleJet i550 InkJet Printer
White lines in print
Does the printer have replaceable printing heads, or are they integral to the ink cartridge. If so they may need replacing or calibration. Another issue may be electronic contacts, check inside the printer and on the cartridges for any dirt or debris on the (usually copper colour) contacts on either end.
Also, if possible try the printer on an alternate computer to ensure it is not a problem with your software.
Kind regards, ACD
Jun 10, 2008 | Office Equipment & Supplies
Printer prints each line 3 times
There are a number of possible reasons for the problem you are experiencing: 1. The printer head might need alignment - use the printer?s software to align the heads 2. Does the problem occur with different cartridges? Try with an old cartridge before opening a new one. 3. If the ink is smeared you might want to clean the printer - make sure no hair or dust balls inside.
Aug 23, 2006 | Compaq Inkjet Ij300 Printer
Epson Dot Matrix LQ-300+ Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
