Question about Clarion DRX6475
I cannot figure out how to adjust the Highs and Mids on my DRX6475. I bought if from a friend from work so I'm starting to wonder if its something wrong with the radio itself. Thank you :)
4 Suggested Answers
dancandoit
  • 436 Answers
SOURCE: I have a pioneer head unit deh-400ub, whats the
speaker mounting is key to a good sound, make sure your speakers are mounted well and the wiring is correct, if you get the speaker wiring wrong it will loose all Bass.
Posted on Nov 21, 2009
  • 4 Answers
SOURCE: setting up the functions for my alpine cda-9886
It is really a preference. Try increasing, then decreasing each on the type of music you listen to and experiment untill it sounds good to you. It will also depend on the abilities of your speakers.
Posted on Feb 04, 2010
kenw392
  • 2226 Answers
SOURCE: i have 3 outputs on my head unit (front, rear, sub) and the clarion eqs746 has only one main input.. .. which rca output do i use.. .. i have 3 amps for front mids and highs , rear mids and highs and
You can use either the front or the rear, it won't make any difference which one you use.
Posted on Mar 14, 2012
My mids and highs have cut off but my subs still work
are mids and highs amped? if so check fuse. many people forget about fuses. if running off head unit only, then the internal amp in the stereo in probably burnt up. if this happened you can run an external amp from the front rca outputs and problem solved with better sound than before!!
Jan 08, 2013 | Car Audio & Video
Audio settings for pioneer DEH-P3100UB
The q1w and all that- is a way to fine tune your eq settings: the q means "frequency" the w means wide and the n means narrow. if you choose to boost your lows at 125 hz which is a low midbass the q selection you choose will focus more on the frequencies very close(narow) to that frequency. if you choose a w setting it will spread the boost to frequencies further away(wider) from the center frequency(125hz) Dink around with it and you will notice the way it contours the sound a little. The different numbers associated with the lows mids or highs are the frequencies that you want to boost when you're adjusting your sound-example if you turn up the bass and it starts distorting your speakers = go into settings 2 and change the "lows" Q to a higher frequency(change 80 hz to 125hz) and that way it wont muddy up your sound quite as bad if at all
Jan 15, 2010 | Pioneer DEH-P3100 CD Player
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Dont know how to set my crossover! mtx rt-x03a
This unit had a couple unique features: a center channel (summed) output and a differential output (right channel is subtracted from the left). Once you figured out you lows, mids, and highs. Center and rear. I recommend buying a cd to test out your sounds like your high, mids, and lows
Mar 06, 2009 | Car Audio & Video
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
Proper mode settings
Hi bongodboss
The user manual for this amp has good instruction on how to connect it. You can download a copy from here.
Page 9 has info about using the amp for "bi-amping" The amp is only a stereo unit, so to do a 3-way system, you will need at least 1 amp mono in bridge mode for lows, and other stereo amp for mods, and another stereo amp for highs. You could use the internal low pass filter for the bottom end, and a 2 way crossover for the mids and highs. Much simpler doing a 2 way system with composite bins for mids and highs, and subs for lows. You only need the 2 amps and use the low and high pass filters inside the EP2500. If you need anymore help on this, I am happy to talk to you more.
regards
robotek
Jul 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
JL 300/4
maybe the remote power lead for the high's amplifier is loose...
May 17, 2008 | Jl Audio 300/4 Car Audio Amplifier
Car Audio & Video Logo
107 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
