Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
My husqvarna mower has quit moving. The engine runs smoothly but when I shift out of neutral, nothing happens. It stopped working suddenly. I have moved the small lever in the back that allows you to push the mower in and out with no results. Is there somewhere for fluid or something similiar to get it going again?
    Brigadier General:
  • 3,911 Answers
Either the drive belt from the engine to the top of the transmission has broken or gone slack due to a tensioner issue, or the transmission has failed. with the engine NOT running you can put your hand up under the deck and feel the topmost belt, if it is there and snug, then you have a transmission problem and that requires a replacement.
Posted on May 25, 2011
My Husqvarna YTH2148 B yard tractor with auto transaxle and 48: mower deck is stuck in gear. Will not free wheel when shifted into neutral. How do I release? Thanks.
This fender shifted unit may need to be adjusted via shifter linkage. The linkage may not be finding neutral when the lever is in neutral. Try to move the lever easily into forward or reverse to see if the transmission can find neutral. If you can, then the linkage will need to be adjusted to compensate.
Nov 21, 2016 | Husqvarna Garden
My 1998 Chevrolet Malibu is giving me trouble. It runs smoothly most of the time but often the engine will quit running while decelerating suddenly for a sharp turn of a full stop. How do I fix.
Save yourself some money , Take it to a ASE repair shop an have it diagnosed ! don't just replace parts have it hooked up to a diagnostic scan tool !
Jun 15, 2015 | 1998 Chevrolet Malibu
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Concerning gear shifting. I have an 86 VT500. I bought it with 14000 miles on it and have ridden about 600 miles of my own since. Downshifting from neutral into first (when prepping to move) it is rough...
Don't shift from neutral into first until the engine is at idle or just above idle. NEVER force the shift lever. The shift forks engage into "slider" gears and the dogs on the sliders must mesh into the side of the gear you are shifting into. The "clunk" you hear is the slider engaging a gear that is not moving at the moment. The higher the revs, the louder the clunk. The diagram shows the slider in neutral. Please rate my answer. Thanks!
Dec 01, 2009 | 1986 Honda VT 500 C Shadow
Concerning Husqvarna LR120 lawn tractor. Gears will not engae.
Recheck your installation. It sounds like you perhaps got the belt on the wrong side of one or more belt guides. If you need an owners manual, post your full model and serial number and I will see if I can locate one for you
Jul 13, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Car will not shift into gear
Sounds like a linkage/cable to me. Disconnect the linkage at the transmission and move the shift actuator by hand to see if there is the same things happening. Don't try to do this with the engine running unless someone is holding the brake inside the car.
Jul 03, 2009 | 1997 Mercury Cougar XR7
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
613 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
