Question about Takara Tomy Tomica 076 Isuzu Giga Dump Truck
White smoke coming out of muffler? - Takara Tomy Tomica 076 Isuzu Giga Dump Truck
Smoke and gas coming out of muffler
p0302 is a misfire in cylinder number 2 white smoke could be from coolant so if the head gasket is blown coolant can leak into the cylinder and cause the misfire are you loosing coolant that might be where its going
Apr 27, 2012 | Cars & Trucks
Bout a bike 2 day been out for a hr and noticed lots oil near the carb n airbox n its seems to be coming frm a pipe which is conected to the top of engine
check your oil level maybe it is more than full if it is good, check your muffler if there is white smoke coming out. if there white smoke coming from your muffler you have a problem in your piston rings, need to be change. thanks...
Apr 27, 2011 | KTM 250 EXC-F Motorcycles
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Apr 03, 2011 | Garden
What is causing white smoke coming out of the mufflers when I start the engine?
It's normal for a thin white smoke to come out of the exhaust at initial start up. This is caused from moisture built up in the exhaust burning off. However if there is a continuous flow of thick white smoke it could be a blown head gasket causing coolant to burn.
Sep 05, 2010 | 1992 Lexus LS
White smoke coming from the muffler, loud noise...
One potential cause is too much gas. It may be running "rich". Your car may also be burning a little oil. White smoke is water or antifreeze. If you are loosing coolant from the radiator, it's probably a blown head gasket. If not, it is just condensation in the exhaust pipe that is evaporating as the pipes heat up. If the car is running too rich, the unburned gas will cause black smoke and burning oil smoke will be blue.
Hope helps (remember rated this).
Jun 01, 2010 | 1990 Honda Accord
White smoke coming out muffler
white smoke indicates that the engine has a leaking head gasket
May 24, 2010 | 1999 Mercury Cougar
Distinct white smoke coming muffler area, we
i would drain the oil and re-check the amount you put back in.
May 02, 2010 | Toro Lawn Mower With Toro Power Tools
White smoke coming out of muffer
With white smoke coming out of the muffler, that is a sign that engine is burning water also. Check your radiator coolant level for this. There is a possibility the head gasket is the problem for this.
Nov 02, 2009 | 1992 Acura Legend
Blue/white smoke from muffler, but when muffler is removed smoke disappears
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
Aug 03, 2009 | Briggs & Stratton Garden
Lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Apr 05, 2009 | Garden
Takara Tomy Tomica 076 Isuzu Giga Dump Truck Logo
14 people viewed this question
Top Takara Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Takara Toy Expert? Answer questions, earn points and help others
