Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
How to remove old printhead - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
How to remove the printhead from an HP 6520
Step one: Remove the old cartridges
  1. Press the Power button ( ) to turn on the product, if it is not already turned on.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing. Figure 1: Open the cartridge access door c02937518.gif
  3. To remove an old cartridge, press the tab on the front of the cartridge, and then pull it up to remove it from its slot. Figure 2: Remove the cartridge from its slot c02938232.gif
  4. Repeat the previous step to remove each of the cartridges.
Step two: Remove the old printhead
  1. Lift the latch handle on the carriage until it stops. Figure 3: Lift the latch handle c01795083.gif
  2. Lift the printhead to remove it from the carriage. Figure 4: Remove the old printhead c01795084.gif
    Regards
    Gary
Jul 07, 2014 | HP Photosmart 6520 e-All-in-One -...
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot get old printhead out does not work would to install the new old
before you removed the printhead out make sure its on the middle of the printer first., remove both ink cartridges., now theres a small tab on the upper left corner of the printhead press that tab then it will remove., and also you can press the tab of of the printhead on the middle upper part portion., those tabs is slightly hidden thats why your cannot see it
Nov 02, 2009 | Kodak ESP 5 Printer
How do you remove the old printhead? We have a
Here is a link to a PDF I have:
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
Jul 08, 2009 | Kodak Office Equipment & Supplies
How do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Jun 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
REMOVING OLD AND PUTTING IN A NEW PRINTHEAD FOR KODAK 5500
Remove both cartriges and on the top left there will be a button. Push and remove the printhead. Net, take the new one and insert it, pushing on the thumb picture. Reinsert cartriges and align.
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Remove printhead
The User Guide (PDF installed on installation) has specific instructions, summarized below:
1 Make sure the EasyShare AiO is on.
2 Open the printer access door. The carriage moves to a center position.
3 Wait until the printhead is idle and silent, then pinch the pinch latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
4 Unlatch the printhead by pressing the button in the upper-left corner of the carriage
5 Remove the old printhead.
6 Remove the printhead from its bag
7 Remove and discard the clear plastic casing and the orange protective cap.
8 Place the printhead into the carriage.
9 Push against the back wall of the printhead until it clicks into place.
10 Reinstall the ink cartridges.
And you are done!
Mar 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I remove old printhead and install a new one?
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Remove printhead
please don't repeat post as i said before, remove both ink cartridges. on the top of the printhead, near the left there is a button. push it and the old one should come out. to put in the new one take all the protectors off and push it in where the old one used to be. push on the thumbprint until it clicks and reinstall the cartridges.
Jan 18, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need instructions for putting in a new printhead
Hello ahieser,
To remove the old printhead, you need to remove the ink cartridges first. And then remove the printhead by pushing the button at the top of the printhead while disengaging it from the carrier.
^_^
Nov 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
21 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
