Question about Polti Vaporetto 2000R Vacuum
The machine just stopped working and I cant find anyone to look at it in Plymouth
I have a dyson DC23 and the turbine head will not turn anymore can anyone help on how to reset. I have cleaned it and there is no blokage its just stopped? Please can someone help
  • Pull the plunger into the ''out'' position for vacuuming carpets.
  • For vacuuming hard floors push the plunger into the ''in'' position to stop the brushbar spinning.
  • Refit the tool onto the machine and test.
  • turbine_plunger_in_out%20jpg.ashxHas this resolved the problem?
    Dec 05, 2012 | Dyson DC23 Bagless Canister Cyclonic...
    We have an Epic6500. when we plug it in the machine works without the hose. We even purchased a new hose thinking there was a problem with the hose. However as soon as we put the hose on the machine the...
    Wow, this is a good one. I wonder if anyone has wrked on this machine before. Do you remember what happened when it stopped working / Obviously there is a foul up in the wiring. I need more info. When the machine is on does it shut off as soon as the hose is plugged in? All I can figure with the info. I have is the hose is plugged which overloads the machine overheating it and the heat sensor shuts it down. But, if bought a new hose that cant be can it? Check the hose anyway for clogs. Blow in the hose with your mouth and se if the air goes through easily. Also, check the back side if the machine to see if the motor is hot. Please, let me know what you find, this is weird. After fixing Electrolux for almost 25 years I have never come across this. Chris email me crash_59@shaw.ca
    Feb 22, 2011 | Electrolux Epic 6500 Vacuum
    Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
    If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
    I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
    Dave in Texas
    Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
    Dyson 17 Brush Motor not working. I was an idiot
    I am so sick and tird of this happening to me- it seems like the sammlest things cause my brusj motor to stop. It has happend 4 times, 3 of which were covered under warrenty and cost $80 in shipping to have fixed everytime!!! I am now out of warrenty and refuse to pay that kind of money for a machine that was alreaydy over priced. So I would love to know if you found an answer to your question...
    Dec 05, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Hello, I have an Electrolux vacuum. In desperation, I vacuumed up some water and my machine stopped. I am hesitant to take the machine to a repair place for fear that if it is a simple repair they will not...
    Although it's never to be recommended, it is sometimes possible to vacuum up a little water without doing significant damage. However, the fact that your machine then stopped suggests that the electrics got wet. That may or may not have caused expensive damage (probably not), but it is essential that the machine be thoroughly dried out before further attempts to use it. That will involve dismantling it, and my guess is that the labour involved will be the most costly part of the job. A competent vacuum engineer should be able to complete the job in about an hour.
    Good luck! Please remember to rate this response - thank you.
    Oct 06, 2009 | Vacuums
    Bissell Lift OfF Brush Roller Stops Rotating
    They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
    Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
    Will not turn on (
    There is no fuse or circuit breaker on this model. You most likely have an electrical problem. I would recommend you take it to a trusted vac shop for an estimate.
    Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Eureka Atlantis Opti Heat - DON't WASTE YOUR MONEY
    fixya site is not the public media for this complaint
    put it on face book so the world gets to know of the shonky manufacturer
    Oct 07, 2017 | Eureka Atlantis 2595A Upright Wet/Dry...
    My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
    Brush belt is very weak.
    Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
    Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
    Vacuums Logo
    16 people viewed this question
    Top Polti Vacuums Experts
    Billy Detlefsen
    Are you a Polti Vacuum Expert? Answer questions, earn points and help others
