Question about Dryers
My Kenmore 600 dryer does not heat up. It seems to work fine otherwise, is it something I can replace easily just by buying a part online?
    Brigadier General:
  • 3,301 Answers
Check out this blog by hatman,, there are others on this same link, if you still have issues, contact sears direct,, they have a hotline for Kenmore issues http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Posted on May 25, 2011
I have a dryer model number is 697267. The dryer works but with zero heat. How do I find the heating element to replace it?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommendhttp://ping.fm/zJDAM
heatman101
Aug 22, 2011 | Kenmore 700 6972 Dryer
Kenmore 600 series gas dryer not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 26, 2011 | Kenmore 600 7965 Dryer
How do I change the terminal block in my series 90 Kenmore dryer? Should I buy it on the Kenmore website. Is this something I should get a technician to do. Its been a very frustrating day.
The Kenmore site may be the best place to buy that... but you can also look around, you may find it cheaper...
That also con be replaced fairly easily if you pay attention and mark the wires before starting...
Check out these tips as they will help you...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 05, 2010 | Kenmore Dryers
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
I have a Kenmore 27in electric dryer. It runs fine, except that it will run an entire cycle thru in only about 5 minutes. What would cause this? I haven't done anything to fix it, because I don't know...
That is not that hard to fix and you can easily buy the partsyourself online...
heatman101
Sep 20, 2010 | Kenmore 63942 Dryer
Heating element stays on all the time
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That sounds like a timer problem...
That is not that hard to fix and you can easily buy the parts yourself online...
heatman101
Sep 07, 2010 | Kenmore 62622 Electric Dryer
Dryer model #8565582 does not heat. What is the part number of the heater unit, with limit control attached, that I need to replavce the heater unit? Thank you
heatman101
Sep 06, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 Dryer, motor is going. Is it worth replacing?
Yes, it is still way less money then a new dryer...
heatman101
Sep 06, 2010 | Kenmore Dryers
I have a Kenmore dryer and it is not getting heated and it continues to run as if no timer has been set. The Make is 60 Series and the model is 7671269276712
Timer has gone bad...
heatman101
Aug 31, 2010 | Kenmore Dryers
Kenmore 600 electric dryer continues drying through entire dry cycle and never stops. Is this a sensor problem..or another part that is needed??
Sounds to me like a bad timers...
that is not that hard to fix and you can easily buy the parts yourself online...
heatman101
Aug 28, 2010 | Kenmore Dryers
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
