Question about Magellan SporTrak Map GPS Receiver
Sportrac map I have had this unit for about 5 years and recently tryed to get her going again but when i turn it on it shows my last position and the little hourglass thingy just stays on and i guess it cant get a signal or something. i can leave it on for an hour with no changes at all. any suggestions???
  • swanndr Aug 31, 2008
    Thank you!!
    Worked for me too.
I just had the same problem and I might have fixed it. Erase all your memory and initiallize the unit as if for the first time. Also make sure your batteries are OK and at least 50% full.
John
Posted on Aug 19, 2008
I have a Garmin nuvi 1300. Recently i update the firmware, the routing direction keep on showing some path that passing housing area and very difficult to drive though. At the setting is usual like last...
Updating your firmware will not correct that problem. I think your maps may be out of date and does not know what to do. I don't know how long you have had your unit but if its under a year old Im pretty sure your entitled to free updates for your maps. If it over a year old then you need to go to www.garmin.com and purchase new updated maps.
I hope this helps you out if it does please click YES on the web page that you are receiving this response on. Thank you
Apr 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
2004 E150 van wont start. -5 degrees last night, battery is less than a year old and tests out OK according to NAPA test. When key is thrown, just a click is heard. Dash volt meter reads normal,...
START BY CLEANING THE BATTERY TERMINALS. NEG CABLE OFF FIRST THEN POSITIVE. CLEAN CABLES & TERMINALS PUT CABLES BACK ON & TIGHTEN POS. FIRST, NEGATIVE ON LAST & TIGHTEN. IF THAT DOESN'T DO IT. LOCATE STARTER RELAY ON FENDERWELL. TURN KEY TO START. MEASURE VOLTAGE AT STARTER RELAY. IT SHOULD READ NEAR 12 VOLTS. IF NOT CHECK NEUTRAL SAFETY SWITCH. THE STARTER MAY BE STUCK OR WORN AS A LAST RESORT HOLD IGNITION SWITCH IN START POSITION, AT THE SAME TIME TAP ON METAL PART OF STARTER WITH MEDIUM SIZE HAMMER. IF STARTER GOES AFTER HAMMER TEST, REPAIR OR REPLACE STARTER.
Jan 21, 2011 | 2004 Ford E150
Product nuvi 200w/ powering up the device, all that is displayed is a small picture of a gps connected to a pc via usb cord. Have the update card for last year. A message displayed recently that map was...
The reason that the picture of the gps connected to a pc is shown is because the mini usb plug is not pushed in fully into the back of the satnav. This is a common problem with the 200w as it feels like the plug is fully in when it's not.
When the map is on the satnav for a year it displays the message that it's out of date. It can be updated again at www.garmin.com but if it was updated last year it may not be worth the cost of updating it again as there will be few changes. Generally I update mine every 2 years.
Aug 04, 2010 | Garmin North America GPS Map Update Maps...
No data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Apr 26, 2010 | Garmin nuvi 780 GPS
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
I was in Tyler Tx. and could not pull up an address. A couple of days earlier I had a message show up that said something about I needed to update. Not sure what that means or how to go about it. ...
How long has it been since you've updated the maps on the unit? You may have gotten a message stating your maps were over a year old, and recommending you update them. The address in Tyler may have been too new for the unit if the maps have not been updated recently also. If this is not the case, you should be aware that some addresses may show as being in a different city due to ZIP code status. For instance, you may know an address to be in a certain town/city, but it may show as being in a neighboring town in the unit as they share a ZIP code. If you cannot find an address in your GPS, go back to the beginning and re-enter the address. When it comes to the city, however, try, "Search All". See if this helps.
Jan 27, 2010 | Garmin nuvi 200W GPS Receiver
I wa in Vancouver, and there is a new bridge that opened in june of this year. Why would the GPS not able to find it and derrect us to it, instead it was telling us to go take a ferry which is no longer...
Area maps are not drawn up every year. There is easily a several year gap before mappers get back to any given area to map any new changes since the last mapping. If that bridge was just opened, mappers wouldn't have had a chance to add it to maps, allowing it to be added to the map software so you could update your gps device. Basically, the bridge was too new for your gps to know about it's existence yet.
Sep 22, 2009 | Garmin nuvi 255W GPS Receiver
Vw sat nav problem
There may be a setting somewhere to define your 'home' position. It will probably default to this location as standard until you find the setting and reset it to your own postcode/home address
Jul 07, 2009 | Car Audio & Video
GPSC340
You need to go outside with a clear view of the sky and get a satellite fix with the unit turned on (usually a couple of minutes), Then the maps will show your current position. By entering your address you are trying to create a route from current position to your destination. By default the current position is set for Kansas (Garmin US office), but once you have locked onto the satellite your current postion will be the last position before the unit was turned off.
Dec 30, 2007 | Garmin StreetPilot i3 GPS Receiver
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Magellan SporTrak Map GPS Receiver Logo
332 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
